crank widow regulator
Old Jul 3, 2021
DaBrother's Avatar
DaBrother is an unknown quantity at this point
Question crank widow regulator
1999 Civic DX
Left front crank would not get window all the way up. Wife had this repaired three times Third repair lasted the longest. Started having to crank and pull on the window to get it back up. I decided to buy a new regulator since it is to hot to ride with window up all the time.
According to the Haynes manual the window seal is to be pealed out to lift the window out. Had a time getting the widow back in the lower portion of the track. Now can not get seal back in exactly the way it was. Do not know how to get the window clip back in. The top edge of the window does not go all the way up into the seal.
Wish I had started here first. Car is due for inspection this month.
Old Jul 4, 2021
Wankenstein's Avatar
Re: crank widow regulator
This video might help?
Old Jul 6, 2021
Bugman1400's Avatar
Bugman1400 is an unknown quantity at this point
Had the same issue and replaced the powered regulators with new ones and still had same issue. I then replaced the rubber and then the window operated like new. I think whatever coating is on the rubber wears down over the years and the raw rubber provides too much friction against the glass.
Old Jul 7, 2021
Colin42's Avatar
They're supposed to be lubricated once in a while with silicone spray
Old Jul 18, 2021
Bugman1400's Avatar
I tried that a few times, but it didn’t work for me. Was surprised how easy the front door rubber was to replace. The rear were a little more tricky.
old97civic
Jun 28, 2015 10:55 AM
jbander
May 11, 2014 02:51 PM
Biggie Deaf
Exterior
Oct 2, 2006 07:15 PM
nspice
Oct 24, 2004 12:06 PM
murd0c
Jan 28, 2003 01:18 AM
