Hood does not open [information sharing - solved]
Old Jul 28, 2021
DIYfan's Avatar
DIYfan is a jewel in the roughDIYfan is a jewel in the roughDIYfan is a jewel in the rough
My Son drives a 2000 Civic EX Coupe. Several months ago the car developed a problem where the hood was really difficult to open. I would have to pull/push the hood release many times then try to pull up on the hood. I finally decided to replace the cable thinking this would fix the problem.
A few months later the problem returned and it took me 30 minutes to get it open. I asked my wife to pull/push the release while I tried lifting the hood maybe once per minute. I also sprayed Liquid Wrench through the gap between the hood and grill, blindly aiming it to where I thought the hood latch mechanism was. The (new) hood release handle separated from the cable from too much aggressive pulling.
So, this time I replaced both the cable and hood latch mechanism. The problem is finally solved and opening the hood only requires a gentle pull of the hood release for the hood to magically pop up. Both parts are pretty cheap and fairly easy to install so I would advise anyone with a similar problem to just go ahead and replace both.
Old Jul 28, 2021
Re: Hood does not open [information sharing - solved]
there are some room to adjust the hood position also, depending on the case. Anyway, thanks for sharing your case, much appreciated!
Old Jul 28, 2021
Colin42's Avatar
Latch was the original problem, lubricate liberally and frequently if you're in an area that sees snow
Njr
Exterior
Jul 15, 2021 12:48 PM
coolfez
Sep 25, 2011 11:22 AM
dezod
Engine Swaps
27
Dec 4, 2006 12:50 PM
EuroEMII
Aug 10, 2006 06:41 PM
mndthegap1
Nov 21, 2002 07:56 AM
