door wont open
Old Feb 21, 2019
velozp's Avatar
velozp is an unknown quantity at this point
door wont open
I know this is a pain in the a''' but my 98 civic drivers door wont open inside or out. Many videos on you tube but want some ideas how to attack this. My key does lock and unlock both doors but the handle on the inside and out do nothing to open the door help!
Thanks
Old Feb 22, 2019
Colin42's Avatar
Re: door wont open
Latch is seized, I had the same problem on my girlfriends '99 but it was the front passenger door.
Go ahead and grab yourself another latch before you attempt to replace it, junkyard will be cheapest.
The last post in this thread has the write up I used to get the door open and swap out the latch.
https://www.civicforums.com/forums/2...-actuator.html
Old Feb 23, 2019
mx5med's Avatar
mx5med is an unknown quantity at this point
Re: door wont open
I had this happen about 5 months ago to me. I forgot exactly what they call the part, but it was a small pin or part on the latch that became worn down or broke. It was a huge pain, but I had to remove my door panel which took forever, and then used a butter knife bent at a 90-degree angle at the tip to open it up. There's a youtube video out there on how to get it done. Try to have patience and you'll get it done.
Added, here they are:
Old Mar 12, 2019
velozp's Avatar
Re: door wont open
Hello guys I got the door panel off with the door locked shut but how many screws mount the door actuator? I thought only 1. And how do you get the black plastic protective cover near the actuator off? One screw is off. A lot of vides out their but they are 4 door civics. Mine is a 2 door ex 1998 . I was quoted $500.00 for the entire job. I'm stubborn and wont pay thanks to forums like this. I need to move or remove these so I can try to move the stuck pin so I can open the door to replace the entire latch assy.
thanks
Old Mar 12, 2019
Colin42's Avatar
Re: door wont open
i think it's like 3 screws for the actuator and then the 3 big phillips for the latch, you can remove the latch and actuator as an assembly,
should only be the one screw for the black cover, maybe you took out a different one by accident?
just keep prying in different areas, worse comes to worse, break it. you're putting a new latch in anyways.
Old Mar 12, 2019
old97civic's Avatar
old97civic is an unknown quantity at this point
Re: door wont open
Look for the 96-00 service manual in pdf format, it's out there
Chapter 20 has several illustrations that give a lot of info on how the door is put together
Old Apr 8, 2019
velozp's Avatar
Re: door wont open
Success!! I got mine from Majestic Honda online for $90.00 shipped to my house works like new, no more Daisy Duke method.
Thanks to all
This definitely tried my patience
ccasey
Sep 7, 2016 07:44 AM
nixyfior
Sep 14, 2015 08:32 PM
carvedtop
May 28, 2012 01:20 PM
kfam5
Jul 7, 2010 02:48 PM
manofsteel517
Nov 7, 2009 05:19 PM
