98 Civic EX - Erratic idle
Old Jun 1, 2019
Lemur's Avatar
Lemur is an unknown quantity at this point
I replaced a battery on a 98 Civic. After that, the car starts fine, runs fine for a couple of minutes, then starts with an erratic or searching idle... up and down, up and down.
It is not my car, I don't own a honda. so I am taking a guess here... vacuum/air leak, which causes a problem after the car warms a bit, car goes from open loop to closed loop and O2 sensor(s) kick in. If so, is there any obvious place to look, since I just replaced the battery and perhaps knocked something loose?
Second guess would be IAC... again, any thing to test or obvious place to look since the this only started with battery replacement?
Thanks!
Old Jun 1, 2019
mac25's Avatar
Dr Krieger of Modification
Re: 98 Civic EX - Erratic idle
I now the 2001+ civics do a self adjusted idle reset if the battery is removed.
You basically don't touch it for 2 minutes until it locks on to a steady 750rpm idle. It needs to complete this idle hunt once then the basic settings are stored until the battery is removed again.
Not sure if the same applies for your generation.
Amtinez
Jan 9, 2015 08:43 AM
gibbs82
Aug 19, 2013 06:59 PM
JDM for Lyfe
Jan 19, 2013 01:49 AM
Typh
Jun 6, 2012 02:24 PM
strykker118a
Jan 31, 2011 11:43 PM
