98 Civic EX Charging System bad
Old Jan 18, 2013
JDM for Lyfe's Avatar
JDM for Lyfe is an unknown quantity at this point
I did a midtronics test on my battery awhile ago and I don't remember if it said it was good or bad or neither but it did tell me to test the charging system so I did and it failed. I took a look at the alternator and it looked pretty old. So if the alternator is fried and the car is running off the battery the engine may idle rough right? Well it does. Once she's all warmed up when I come to a complete stop it will idle quite low. When I click the window up button the idle will raise for a bit then drop down again. Same with pressing the brake. Will a new battery and alternator solve my rough idle?
Old Jan 19, 2013
Re: 98 Civic EX Charging System bad
looked pretty old
Since when does old=bad?
Did anyone test it (I know you just said you did, but how)? Are the fuses all good?
Not if the battery is still charged up. Unless the alt is pulling some excessive load.
Probably not, but maybe....
CarStuff
Dec 6, 2020 12:52 PM
tylerginevan
Apr 27, 2015 12:29 PM
alexkharden
Apr 23, 2015 07:13 PM
WhosYoDadday85
Bolt-on Engine Performance
Nov 6, 2001 08:06 AM
wsking77
Aug 30, 2001 12:32 PM
