Idle problem lights dimming while idle jumps up and down
Old Jan 8, 2015
Amtinez's Avatar
Amtinez is an unknown quantity at this point
My 2002 honda civic ex 5 speed idles kind of like it pulses while in neutral during this the headlights on the car Dimm nsync with the pulses/rough idle I bought a new battery, still the same problem. I left the car running and disconnected the positive terminal on the battery and the problem went away completely. When I reconnected the positive terminal the pulsing /rough idle returned. Does anybody know what may be causing this problem? help would be appreciated.
Old Jan 9, 2015
jordan1794's Avatar
jordan1794 is just really nicejordan1794 is just really nicejordan1794 is just really nicejordan1794 is just really nicejordan1794 is just really nice
Re: Idle problem lights dimming while idle jumps up and down
The pulsing,as far as I can tell, appears to be directly linked to your alternator kicking on and off
(Supported by the fact that, when you disconnected the positive you effectively disconnected the alternator from the battery)
Get a battery / charging system test done.
Also, I believe this is in the wrong sub-forum, maybe a moderator will move it.
mikemc422
Aug 9, 2018 05:41 PM
crowtoo
May 11, 2015 06:50 PM
jakeconnor
May 5, 2015 07:30 AM
dragonsblood
Apr 27, 2015 12:28 PM
SSMatey
Apr 13, 2015 06:09 PM
