Electrical Post your Electrical issues here!
Obd1 Gsr swap onto obd2 (2000 civic)
Old May 25, 2020
Josh Nebroskie's Avatar
Josh Nebroskie is an unknown quantity at this point
Having trouble with figuring out why my timing is messed up. Everything is aligned up mechanically tdc is perfect cams are right on point. Distributed is allighned to rev of cylinder #1. But anyway the car runs very rough at low rpm anything below 2k and won't idle unless I give it gas to 1000 rpm or adjust the throttle cable to keep it there. There are no cel codes or lights and yes i did jump the connector to do the timing but the red timing mark is on the other side near the alternator when I shoot the gun at. I have checked every sensor tps ,map, knock, o2 sensor and rebuilt the distributed checked the resistor and put known working parts in it. I also switched between 3 ecus 1 p30 with Hondata s200 with a tune with came with the car and 2 stock ones that were pulled from running cars. I have also recently tried to bypass the crank position sensor by tapping 2 sets of 2 wires together to no avail. I am completely lost at this point. Any help would be a life saver
Old May 25, 2020
Re: Obd1 Gsr swap onto obd2 (2000 civic)
have you put the correct sequence of wires to distributor?
if yes, move distributor some degrees both ways and see if it helps.
I used to move it while running in other cars, but be careful to not get shocked.
check for cracks on distributor cap, pretty common occurrence.
Old May 26, 2020
I'll try adjusting it while running tommoro. Never really thought of that honestly. Thanks for the input!
Chad1971
Oct 19, 2025 10:23 PM
Joecrowe
Sep 19, 2015 07:48 AM
Turboedb18
Feb 6, 2015 04:48 AM
daddyblue
Aug 20, 2011 04:00 PM
xRiCeBoYx
Engine start problems
71
Apr 9, 2011 01:40 PM
