passenger window
Old Apr 12, 2015
coupeciv's Avatar
coupeciv is an unknown quantity at this point
passenger window
I have a 02 civic lx coupe. And the passenger will roll down but wont roll up. The only way it rolls up is from the d/s switch. What could it be. Or how can I fix this Problem.
Old Apr 12, 2015
GolNat's Avatar
Prelude Owner
Re: passenger window
Sounds like the switch might be bad. Since it does go up and down it sounds like the regulator is operating properly.
Remove the door panel and test the switch.
Old Apr 14, 2015
keemoblk's Avatar
keemoblk is an unknown quantity at this point
There is a door harness connector behind the side view mirror adjustment switch. Remove the storage box to access it. There may be high resistance at this connector. Try unplugging it . Plug it back in then wiggle it as u are trying to operate the window. If it works that's your problem. To properly test it Pop out the driver side window switech assemblY. Then pop out the passenger side window switch assemby. Leave the plugs connected to the switches..Now check continuity between the passenger switch wiring and the drivers switch wiring with a multimeter.connect the meter to the wires on the passenger switch to the drivers switch that are the same colors. if u find a wire that has high resistanece. Cut both wires on the connector behind the side view mirror switch and splice them together. You will be basically bypassing or jumping the connector.
Old Apr 23, 2015
Trav_02civic's Avatar
Trav_02civic is an unknown quantity at this point
Remove the door panel and check the window switch it sounds like it shorted a circuit could be from getting wett if the switch is good then check for obstructions in the window tracks inside the door still if thats all clean the window regulator could be about to go out time to change it
wingsfan19
Oct 1, 2015 03:45 AM
Sep 27, 2015 11:33 AM
Dsmak
Sep 10, 2015 08:30 PM
Dave Brabant
Sep 9, 2015 08:11 PM
Wiggles
Sep 8, 2015 05:05 PM
