2008 door lock issue
Old Jul 11, 2022
NCCarGuy's Avatar
NCCarGuy is an unknown quantity at this point
Hello all. I have an 08 Civic, and am having a strange issue with the driver's door lock. The driver's door lock will ONLY lock if I manually flip the lever. Power locks and remote will not lock the door. All other doors are fine. When the door is locked, the power door lock will unlock with both remote and power lock button.
I was told to replace the actuator; I did, and nothing changed!!! Any help / advice would be awesome!
Greg
Old Jul 11, 2022
Colin42's Avatar
Re: 2008 door lock issue
Need to see if the actuator is getting a lock signal
Old Jul 12, 2022
NCCarGuy's Avatar
How would i do that? When I push the power lock button on the remote I can barely hear something by the actuator - but nothing happens on the driver's door
Thanks!
Greg
Old Jul 12, 2022
during the replacement, did you check the wiring/connectors?
Old Jul 12, 2022
NCCarGuy's Avatar
I did. What's also strange is if i manually lock the driver door from the inside, it activates the power lock system and locks all the other doors! I guess this is supposed to happen? Sorry - this is my first Honda, so not sure what's "normal" and what's not.
Old Jul 12, 2022
Colin42's Avatar
Thanks!
Greg
With a multimeter, if you hear the actuator trying then it could be bad out of the box. Or it has a bad power/ground
Brian Bills
15
Mar 19, 2018 11:33 PM
eddie1976
Nov 10, 2016 07:00 PM
Gorila
Apr 4, 2011 06:32 AM
Maple50175
Jul 6, 2007 12:16 AM
dELfONiK
Aug 4, 2005 10:18 PM
