door lock issue *can anyone check this on their civic*
Old Jun 21, 2007
Maple50175's Avatar
Maple50175 is an unknown quantity at this point
Ok, so I believe my actuator went to ****.
When I am in the car, I try and use the lock button to lock my door and all that happens is the passanger side door locks but not the driver side. When I push the drivers side door lock the actual up and down peice it will lock the other door.
Can someone go out to their car and sit in it and use the lock/unlock to see if it will lock the drivers side door.. I want to put my alarm in but it will be useless if I have to use the key to lock/ unlock the doors and be more of a pain in the *** so yeah let me know what you can do for me.
Thanks alot.
-Wayne!
Old Jun 21, 2007
Boilermaker1's Avatar
Jap-Euro Fusion
Re: door lock issue *can anyone check this on their civic*
if you push the lock button on the driver side door next to the handle (or the keyless remote) it should lock all the doors.
Old Jun 21, 2007
Maple50175's Avatar
****, its not,
So would it be the actuator that **** the bed? Is there any way I can confirm that it is infact the actuator
Old Jun 22, 2007
LT2004ever's Avatar
I wil fix vBPlaza today
my drivers side works but my passengers side doesn't. grr...
Old Jun 22, 2007
greeen01civic4d's Avatar
its def the actuator, ive done this on my fiance's car already, its a bitch, but th epart is like 25 bucks at honda, its worth it tho
Old Jun 22, 2007
varnz's Avatar
varnz is an unknown quantity at this point
if you are locking the doors from the inside then you have to pull on the drivers handle like you are opening the door in order for that door to lock. if your locking in from the outside and the door is closed and it doesnt lock then it is the actuator. but if it does there is no problem, you just have to remember to pull on the handle from the inside in order to lock the drivers door. i think it just a safety feature so you dont lock ur keys in it. i have owned to civics a 96 and an 04 and they are both the same way
Old Jun 22, 2007
02BLKCIVIC's Avatar
Official Rattlesnake Hunter
yup its the actuator
Old Jun 23, 2007
Maple50175's Avatar
awesome thanks guys, gonna order a new one soon!
Old Jun 25, 2007
John04Civic's Avatar
John04Civic is an unknown quantity at this point
So let me get this straight ( I have the same issue ):
My keyless will NOT unlock / lock the driver side door, but if I do it from the inside only the passenger side works fine with no issues.
So do I need an actuator also? From what I am reading that means yes, but I'd like to be sure.
How hard is it to install this part?
Old Jun 26, 2007
bryantiscool's Avatar
bryantiscool is an unknown quantity at this point
i have the same exact issue. so basically a new acuator is in need? there's no way that i can just pull apart the door panel and spray it with a lil wd-40 and see if it'll work?
Old Jul 6, 2007
sl33pyriceboi's Avatar
[i just found this thread by searching]
freaking a.... this just happed to me yesterday...i come bak from vacation and my car door ***** on me.
Old Jul 6, 2007
HighBoost's Avatar
HighBoost is an unknown quantity at this point
same **** happend to me maaan... driver side wont lock, passenger side is fine.. hate to take tha big platic off from the door maan...so hard not to break any little things..
roverben
Jan 21, 2019 05:16 PM
MamaBear2015
May 3, 2015 02:17 PM
darwin-t
Apr 18, 2015 09:29 PM
Thees1
Apr 14, 2015 08:23 AM
NoToRiOuSxPiNoY
Bolt-on Engine Performance
Nov 7, 2001 11:19 PM
