Passenger power lock will not work! Help!
Old Mar 6, 2011
Gorila's Avatar
Gorila is an unknown quantity at this point
Hey guys!
I just bought a 2002 honda civic ex coupe. It has a little issue with the power locks. The passenger door will not lock or unlock when I try to use the remote controller, but the driver's side door locks and unlocks normally. Also, when I'm inside the car and try to lock/unlock all doors by switching the button on driver's side (that should automatically lock/close all doors) it only locks/unlocks the driver's side door. The passenger's side window works perfectly, when controlling from the driver's side or the passengers... I just have a problem with locking and unlocking of the passenger's door.
It is my first car and I'm new to the forum, so I don't know very much and I'm afraid of messing up the entire lock system.
I appreciate any help!
Thank you!
Old Mar 6, 2011
K20Z3's Avatar
2010 Civic Si
K20Z3 is on a distinguished road
Re: Passenger power lock will not work! Help!
Sounds like its just the door lock actuator that went bad but get a circuit tester and make sure its getting a current. If so then just get another one from a scrap yard or something (not sure how much they cost) and it should be a simple swap by taking the door panel off etc.
Old Mar 7, 2011
ubnpast's Avatar
ubnpast is on a distinguished road
Its a fairly common problem. Door lock actuator, you can get a new one for about $40
Old Mar 7, 2011
SpeedDownZone's Avatar
Theres two plugs connected to the actuator what current should the there and when?
Old Mar 7, 2011
ubnpast's Avatar
It should be pulsed alternating 12v when you lock or unlock
Old Mar 7, 2011
Sorry for the thread hijack but where should I look if one is always constant even with the unlock/lock button off.
Old Mar 7, 2011
K20Z3's Avatar
2010 Civic Si
Door locks wouldn't get constant currents because they are only used when you lock or unlock. If you need a constant current for running another accessory then I'd suggest looking to the radio or something else in the fusebox that could supply a constant current to whatever you're running.
Old Mar 7, 2011
CraigW's Avatar
^^ The drivers door actuator has 2 plugs (1 = actuator motor / 1 = status switch)
All other actuators have a single connector.
Old Mar 7, 2011
I think you miss understood me there is two plugs on the actuator one of those plugs gets constant electricity dont know if that is normal i think its the one with three wires. the one with two wires on it dont get any even if the switch is pressed up or down.
My unlock/lock swicth dont work remote wont unlock/lock it either and driver door manual unlock/lock button only goes down or up when the door is closed dont know if that is normal.
and again sorry for the hijack but did not want to create a new thread for this.
Old Mar 7, 2011
CraigW's Avatar
The 3 wire is the switch WHT/BLK, YEL/RED & BLK
The 2 wire is the actuator motor YEL/GRN & YEL/BLK
You are most likely measuring voltage from the multiplex control unit. It takes various inputs from items and also outputs for the actuators.
Any other electrical items inop ??
Normal for drivers lock to only work when drivers door is closed.
Old Apr 3, 2011
rustybonz54's Avatar
rustybonz54 is an unknown quantity at this point
Greetings Civic fans. my retired friend has a 2002 Civic EX which has developed a remote door lock problem. after reading about this common problem on this site i bought a new drivers door actuator and did the replacement. same problem but now with a new twist. the original problem lies with the FOB won't unlock the drivers door but if you manually use the key to unlock the drivers door, then the FOB will work on the remaining 3 doors. odd. when you get inside and close the drivers door (and the remaining doors are closed) the drivers door Power Lock switch will lock all 4 doors but will NOT unlock the drivers door. when exiting the car, if you want to lock all doors with the FOB you have to hold the drivers door handle in the unlock position and the FOB will then lock all 3 doors and then you have to manually lock the drivers door. odd. this is the original owner and no accidents. the owner is 70 and is not abusive, takes the buggy to Honda for everything but he is running out of $$$ like the rest of us. he is now railing about just buying a new car but his wife says NO, NO, NO. this Civic has ~120K miles and is in very good shape. any ideas out there? thanks.
Old Apr 4, 2011
CraigW's Avatar
^^^^ I would listen for noise from the drivers door on the 1st unlock press of the fob, listen close to the drivers door inside for any sort of buzzing noise. My 1st thoughts are an open unlock connection leading to drivers door.
roverben
Jan 21, 2019 05:16 PM
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
ORskier
May 3, 2015 12:54 PM
ademarco6
Exterior
Nov 15, 2001 09:36 PM
Ramen
Canada West
Nov 5, 2001 06:07 PM
