How to take off headlights...
Old Nov 18, 2002
xzykotic's Avatar
xzykotic is an unknown quantity at this point
I am having trouble taking off my stock headlights to replace them with aftermarket projectors. Does the entire front bumper really have to be taken off, or is there an easier way? The only bolt I cant seem to get to is the one that holds it on in the inner part (looking at the car, the bolt that is closest to the front emblem). I cant seem to reach it and I was wondering how I can get to it.
Also, while being an ***, I accidently kicked the plastic part off on my headlamp that bolts on the outer edge of the lamp. I think it can be super glued back on, but is that bolt really crucial for support? Will the lamp throttle around if it is not bolted?
Old Nov 18, 2002
impetigo's Avatar
impetigo is an unknown quantity at this point
Check out the DoItYourself (DIY) section:
Taking out the headlights
this one is for clearing your lights, which will tell you how to take off all the stuff you need to take off to take out the lights. To get those hard to reach bolts you'll need to use a wrench for the tight squeeze.
Old Nov 18, 2002
Mex's Avatar
Mex
Mex is a jewel in the roughMex is a jewel in the roughMex is a jewel in the rough
you don't need to remove the whole front bumper, just pull the top forward.
Old Nov 19, 2002
xzykotic's Avatar
What do you mean pull the top forward? On what?
Old Nov 20, 2002
TopFuel's Avatar
Ultimate OG Member
TopFuel will become famous soon enough
ah just remove the whole bumper, not that big of a deal, makes it easier when you're working. theres a bunch of plastic clips underneat and bolts. Just remove all of em, pop off the clips connected to the top grill and your good to go. Pull off the bumper then take off the bolts connected to the headlights. very easy job.
Jeff
Old Nov 22, 2002
sg2kca's Avatar
sg2kca is an unknown quantity at this point
Mex's way was sooooo easy!!! no need to jack up the car, no need to take all those darn clips off......
Old Nov 23, 2002
ak's Avatar
ak
Retired Mod
ak can only hope to improve
Quote
[hr]Originally posted by: sg2kca
Mex's way was sooooo easy!!! no need to jack up the car, no need to take all those darn clips off......[hr]
And best of all, takes like 2 minutes
RNinjA81
Jul 20, 2014 02:25 AM
NAcaRice
HIDs and Retrofitting
Mar 2, 2013 04:01 PM
1.7lciviclx2001
Nov 28, 2009 01:38 PM
ImPulse
Dec 5, 2004 09:20 PM
LogicWavelength
Lighting
Apr 20, 2004 06:43 AM
