Oil pressure problem
Old Jun 23, 2018
SemperFi's Avatar
SemperFi is an unknown quantity at this point
Ok so my engine was rebuilt recently. I have an issue with low oil pressure. It only gives me low pressure after warm up 210° or so and on level ground. Let me elaborate. When the front end is elevated (as in on my driveway 8%grade) the idiot light will not turn on. I have had a gauge on it and it drops to 7PSI. At one point I noticed that the oil pressure would only drop when rpms dropped below 680 but when it is on my driveway the rpms drop but not the pressure. Weird , right? So, help me out. I figure that what ever is causing low pressure is being covered up by the oil when on my drive way. I have already taken out and cleaned throttle and IACV. ANY IDEAS???????
NOTE::::This engine has already had three rebuilt heads and two new Oil pumps.
Old Jun 23, 2018
Re: Oil pressure problem
Oil is at the full mark? Remove a quart or so of oil (maybe 1.5) and see if the pressure then is low enough to turn on the warning light at hot idle. It shouldn't be if there is no suction leak.
Possible sump pickup tube suction leak, maybe bad tube gasket (reused too many times) or cracked pickup tube
Stuck relief valve
Shop didn't actually plastigauge any of the bearings during the build, excessive oil clearance(s)
Pressurize the oil galleries with the pan off and look for a gusher that would indicate hydraulic loss
Old Jun 23, 2018
SemperFi's Avatar
Yes, oil is full. New gaskket on pick up tube. I thought it was bearing clearance from beginning but that would mean that I would get low pressure all the time wouldn't it? The idiot light doesnt come on all the time and never when front end is higher than back end.
Will try thkse things see what happens.
I have seen how to raise pressure on you tube but I want to find the cause and fix it, though.
Old Jun 23, 2018
Slumpertcivic's Avatar
Wonder if one or two front drains in the head might still have service plugs in them or otherwise clogged.
When lifted up, more oil would be able to use the two rear drain holes.
Test for it, park it backwards so the front end is pointing down, start it up, open up the oil cap and see if the entire head is filling up with oil... caution might get messy in a hurry.
Old Jun 23, 2018
SemperFi's Avatar
I did not notice any obstructions on the front drain holes but I will try that first. You never know.
Old Jun 24, 2018
No. Depends on how much clearance (abnormal leakage) there is. Depends on how viscous the oil is. And pump speed too.
You'll have decent pressure as long as the pump can move more fluid than there is leakage, and as long as the fluid is thick enough to give sufficient resistance. As those variables change, pressure changes accordingly.
Pressure decreases after the oil heats up and gets less viscous, that's normal.
This is really weird to me.
Put the gauge on it again and take pressure readings with the car in various positions?
Old Jun 24, 2018
SemperFi's Avatar
Thanks will try that aswell
Old Jun 24, 2018
thicker oil?
Old Jun 25, 2018
SemperFi's Avatar
Ok so I did not try my car at a downward angle because it did turn the idiot light on at an upward angle now. So scratch that angle off list. The only other cause would be the clearances. Like I told the owner from the beginning.
Anyways, I just tried some Lucas oil stabalizer and that stuff works. The idiot light did not turn on after an hour long test drive.
Now I have to see if owner will stiilll accept responsibility. If he does hopefully he gets someone else to work on it. Someone that can use a Mic and knows how to set correct timing.
Old Jun 27, 2018
D17VTECPOWER's Avatar
D17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of light
The Lucas stuff just makes the oil thicker, which is usually not a good thing. You probably have excessive bearing clearance if the Lucas fixed it. That engine probably won't live long.
Old Jun 27, 2018
SemperFi's Avatar
Yeah, I know. I just plastigauged the mains. Let me knkw what y'll think. Pics coming in a bit
Old Jun 27, 2018
Do you know what the factory spec is?
Same deal for the rod bearings too.
Old Jun 27, 2018
SemperFi's Avatar
The only info I found states .0007 - .0014 for #s 1,5
And .0009 - .0017 for #s 2,3,4
I could be wrong though.
ID:	112364   Click image for larger version
Old Jun 27, 2018
SemperFi's Avatar
I didn' t do the rods. Didn't want to get so deep. Y'all think these two are enough to cause the low oil pressure??? I hear a small tick but that might be the valve lash (set to 8 and 10)
Old Jul 5, 2018
Sorry I forgot about this.
Looks like it's at the wide end of the spec range. Not ideal.
I'd say to check the rods.
Too many of these with clearances of 'almost too much' can add up to a total amount (I learned it as "stacking tolerances") that's just more than it should have, more than the pump can keep up with. You end up with low pressure.
Old Jul 5, 2018
SemperFi's Avatar
Yeah, that is what I thought according to the specs I found. I took the car back and the owner has promised to fix it. So, I will let yall know how things turn out. Thanks for ideas and advise.
Old Jul 6, 2018
You're right. Great point!
Old Jul 6, 2018
not your car?
Old Jul 7, 2018
SemperFi's Avatar
Yes it is my car.
Pete6032
May 26, 2019 01:48 PM
juanjo_52
Apr 10, 2015 03:00 PM
Obamargarine
Nov 20, 2009 09:42 AM
Jeff
Aug 11, 2006 12:38 PM
Goku
Jan 22, 2004 07:52 PM
