Starting problem: limp mode unless fed gas
Old Aug 28, 2016
mgcivicdriver's Avatar
mgcivicdriver is an unknown quantity at this point
I have a 2002 LX 1.7 manual drive
The engine light is not on.
I just finished replacing the crank shaft sensor. I didn't tighten the drive belt enough so I had to go back in and do that. This problem started after that.
1) When I start the ignition the starter goes but the engine doesn't start.
2) When I hold my foot on the gas during ignition the car will limp for a bit then start
3) the car seems more sensitive to stalling when in the friction zone of the clutch, especially when in reverse.
4) No other problems when on the road moving.
What do you guys think the problem is?
Thanks!
Old Aug 29, 2016
Re: Starting problem: limp mode unless fed gas
Bump!
Old Sep 5, 2016
mac25's Avatar
Dr Krieger of Modification
You had to adjust the timing belt? If so maybe it's off a few teeth?
mgcivicdriver
Engine start problems
16
Dec 10, 2015 11:58 PM
steve6
Nov 22, 2015 08:18 PM
Shoryuken
Nov 10, 2015 09:35 AM
chilling_pete
Nov 5, 2015 10:05 PM
damahark
Oct 28, 2015 08:11 AM
