help!!! compatibility issue
Old 10-27-2014
hinkle finkle dinkle doo
oqjoi's Avatar
oqjoi is an unknown quantity at this point
Have 02 civic si need a new fuel hanger assembly. The thing under this back seat. It has a crack. I'm leaking fuel. Will an 05 one from an si fit mine???
Old 10-27-2014
Re: help!!! compatibility issue
I can't see anything from here
Pic is from an Odyssey but it shows the general area the cracks form in, the raised roundish area.
If it's leaking from the round disc area on top of that tank unit (see image), you might want to contact the NHTSA
(https://www-odi.nhtsa.dot.gov/ivoq/)
and report it as a defect. This is what one of the current recalls on Odyssey vans is for (the only one I've witnessed leaking so far came from Arizona....I'm up in the rust belt...).
Look up your choices in an online parts catalog and compare part numbers. I'd not want to risk another used one cracking, I'd want brand spanking new.
http://estore.honda.com/
http://www.hondaautomotiveparts.com/
(02 and 05 SI hatchback both use the same pump assembly part number)
HTH
Old 10-28-2014
oqjoi's Avatar
i found the part thank to you guys!!! it is called fuel pump filter ***." or i also found it under "fuel pump module ***." it is difficult to find it. I guess its supposed to be a lifetime part, but not under any types of warrenties. and buying a replacement is around $300 (which i currently do not have). however the used one i found was $50. i figure i can use the used one to get it back on the road and in a few months after saving the $300+ i need to get one, i will. thanks for listing the part number that helped to most. now all i have left is to take the old one out and put the new one in. the only part of the process i'm not confident with is the fuel line. i disconnect it from the pump while the car is running to drain the line correct? otherwise i spray gasoline everywhere. i'll let you know how it goes!!
Old 10-28-2014
NO!
Unplug the pump wiring connector with the engine running.
Let the engine die, then disconnect the fuel line.
There will still be a little pressure so cover it with a rag before you disconnect it.
Old 10-28-2014
Super Moderator
Poopies's Avatar
Welp... I can just imagine this guy (edit: girl) is covered in gas right now
Old 10-30-2014
oqjoi's Avatar
Originally Posted by ezone
NO!
Oh my thank you. I could only imagine the mess i would have made. Not to mention the risk of gasoline everywhere. Undo the plug first, let it die, then the hose. Then i can do the swapping. I plug everything back in whole the car is off, then **** a few times and vroooooom. Hopefully. Without leaks. :-) I'm glad i asked.
Old 10-30-2014
oqjoi's Avatar
Originally Posted by Poopies
Welp... I can just imagine this >girl< is covered in gas right now
Lol i would have been. But that's why i asked now isn't it. :-P
Old 10-30-2014
Pics or it didn't happen!
Old 10-30-2014
oqjoi's Avatar
I'll find a good one
Old 11-02-2014
oqjoi's Avatar
Fixed it. No more leak. I did get covered in gasoline, but not because of the gas lines.
Old 11-03-2014
Super Moderator
Poopies's Avatar
Eh, if you don't get covered in automotive fluids of some sort during a repair, you probably did it wrong! Congrats on the fix though!
Old 11-03-2014
oqjoi's Avatar
Agreed. Thanks again for all the help.
cbalonon
Turbo
15
12-01-2015 03:22 PM
chuffsy
05-16-2015 03:52 PM
Jokerhogan
05-09-2015 02:52 PM
PiCASSO
03-10-2002 01:34 PM
LiKEaFeRiO
02-10-2002 08:10 PM
Quick Reply: help!!! compatibility issue
