Passenger Window Not Moving..
Old Jun 13, 2013
ImSoFreaknWhite's Avatar
ImSoFreaknWhite is an unknown quantity at this point
Hey guys, I'm new here and just picked up my first ever Honda. Its a 2001 civic coupe EX. When I purchased the car, the window didn't work. Now my question to you guys is if there is any thing I could check that could be causing it to not roll down? If not im going to spend the money to get a new window motor/regulator and swap it out. But Im afraid ill do all that and find out it was just a small issue that caused the problem.
(Yes I already checked if it was the window lock button and that's not the problem lol)
Thanks
Old Jun 13, 2013
got2run5's Avatar
got2run5 will become famous soon enoughgot2run5 will become famous soon enough
Re: Passenger Window Not Moving..
This could be one of several issues so don't go out and buy a new motor/regulator. Get a an electrical diagram of the power window circuit either from here or a google image search or something. It isn't too hard to find. I had issues around a year back so if you search my old posts you can probably find it. My problem ended up being a broken ground wire. Even without the diagram you can tell if the problem is the motor by checking the voltage going to the motor. When the switch isn't up or down, there should be an open circuit at the motor so you would get 0 V. At Up/Down switch, the voltage should be a positive and negative value. If the switch at 0V and the power window lock is off then your motor is fine and you have an electrical issue and you need to go into deeper testing with the circuit diagram. If you have voltage to the motor and the motor still won't run then you need to buy a new motor/regulator. I hope that makes sense-I've had too much coffee and am a tad scatterbrained.
Old Jun 13, 2013
CraigW's Avatar
https://www.civicforums.com/forums/a...7&d=1350598426
Old Jun 14, 2013
Umm it somewhat makes sense. But regardless I appreciate the quick reply. ha so basically I need to test out the power that's going to the switch/window before I jump to a new motor. And check to make sure that all the fuses and wires are good and working. I believe the diagram you were referring to was just posted above. I think it seems a little out of my league so im going to take it to a shop to check it out.
thanks again though.
Old Jun 14, 2013
Thanks for the diagram
Old Nov 16, 2013
moved to clean DIY forum section - intended to posts that are guides/references to solve issues.
fvckbg
Oct 20, 2016 07:37 PM
wingsfan19
Oct 1, 2015 03:45 AM
Sep 27, 2015 11:33 AM
Dave Brabant
Sep 9, 2015 08:11 PM
Wiggles
Sep 8, 2015 05:05 PM
