Front Motor Mount Help
Old Feb 18, 2012
tinktink36's Avatar
tinktink36 is an unknown quantity at this point
First time posting on here, and not super mechanically savvy. But I am replacing my front drivers side motor mount. Bought new mount and bracket together for under $100, got my engine jacked up, old broken mount off, I just can't seem to get the bracket to go on. I got the mount itself put in, but after the mount is in place the bracket doesn't line up correctly. Anyone else have this issue? Or know of ways to fix it? Any help at all would be much appreciated!
Old Feb 18, 2012
MindBomber's Avatar
Live for the Twisties
Re: Front Motor Mount Help
The position of the engine has shifted, jack it up a bit and the holes should line up.
Old Feb 18, 2012
Don't tighten anything until all the hardware has been "started" in the threads.
Old Feb 18, 2012
tinktink36's Avatar
Tried jacking the engine up a little more, still not lining up. I also tried to line everything up before tightening everything, still could not get all the bolts to line up.
Old Feb 18, 2012
Use your hands to move the engine around. Or a pry bar.
Old Feb 18, 2012
tinktink36's Avatar
Got it! Used the pry bar and it slipped right on. Thanks to both of you for the help!
Old Feb 19, 2012
i hope you got the right one...
https://www.civicforums.com/forums/3...ne-mounts.html
Old Feb 25, 2012
tinktink36's Avatar
I did get the correct mount, I knew of the difference in the sedan and coupe mounts before purchasing, so I double checked everything. Good info on that thread though!
Old Dec 12, 2012
Matt_75's Avatar
7th Gen Civic DIY Enthusiast!
Any one see a problem with this front motor mount? I was thinking of just super gluing back in.
Old Dec 12, 2012
This guy just called:
Said that mount looks like it is shot all to he!!.
Have you seen a DIY for making/repairing mounts using some sort of urethane?
Old Dec 12, 2012
Matt_75's Avatar
I have, but I'm good with just replacing these every view years. Not too many mcdoubles compared to a car payment.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
Jigee
May 9, 2015 11:18 AM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
bsmiley
Apr 27, 2015 01:27 PM
GH04si
Apr 15, 2015 08:13 PM
