Random Power Loss
Old Aug 22, 2009
renaldodesilva's Avatar
renaldodesilva is an unknown quantity at this point
Random Power Loss
Hi All,
I've been suffering with random power loss issues with my 2004 Civic for the past 3 months. I've gone to at least 5 mechanics none of them were able to solve my problems.
I've purchased an Innova scan tool and have been driving around with the car for the past two weeks records sensors readings and DTCs. I had a bad O2 sensor so I ordered a replacement and swapped that out today, unfortunately it hasn't resolved my problem which has gotten 10 times worse about a week ago, so bad that I can't drive the car 100 metres without the problem manifesting itself.
I'll list the current codes being thrown below let me know if anyone wants the sensor readings I'll upload an excel document with them to a web server and provide a link for you to download it.
I've been unsuccessfully trying to confirm from the person I purchased the car from whether the engine was ever changed I suspect it was. I'm leaning towards the problem being some sort of electrical short and would like to diagnose that before I attempt to replace the ECU, do you think that could be the cause? The car appears to loose electrical power for a split second, the engine check light flashes, the car bucks forward and then goes back to normal, sometimes the check light will stay on and car doesn't accelerate, it has only completely stalled 3 times since the problem started about 3 months ago.
DTCs:-
P1213
P1253 - VTec System Malfunction
P0336 - Crankshaft Position Sensor A Circuit Range/Performance.
A complete thread of the issue an suggestions from an online mechanic can be found at
http://www.justanswer.com/questions/...vic-d17-manual
Thanks in advance for any assistance.
Old Aug 22, 2009
seoul4korea's Avatar
seoul4korea can only hope to improve
Re: Random Power Loss
Im having the same problem! I think..... https://www.civicforums.com/forums/7...ml#post4431824
Old Aug 22, 2009
well for the o2 sensor problem and power loss, your cat converter could be clogged. for the other codes, replace the crank position sensor and clean the vtec solenoid filter screen. if that doesnt work, you need a whole new solenoid. its located in the rear of the engine with a cylinder cap on top.
Old Aug 23, 2009
I'm sure it's not the CAT as the car currently doesn't have one installed. Do you know what the part numbers are for the crank position sensors and vtec solenoid? Or where I can buy them online?
I doubt it's a vtec problem though as the problem occurs even when teh car is idling.
Old Aug 24, 2009
Tomj333_EM2's Avatar
Tomj333_EM2 is an unknown quantity at this point
how do i go about cleaning said vtec solenoid?
Old Aug 24, 2009
just take it off and clean it up. the screen gasket comes out too and you can wipe it with a clean cloth.
Old Dec 5, 2010
estee96's Avatar
estee96 is an unknown quantity at this point
hello. Been having the same electrical problem with my civic. Any news on how to solve this? Been with a few electricians, cant seen to solve my problem: Lights dim when I hit the brakes; radio turns off for a split second when I hit the lights. HELP!!!
Old Dec 5, 2010
they are talking about engine power loss, buddy... go to the electrical section...
FutureCivicOwnr
Aug 11, 2015 10:59 PM
jzhartman
22
Jul 23, 2015 10:42 PM
mistermenphis22
Jul 13, 2015 04:43 PM
1khilari
Jul 9, 2015 08:12 PM
Youshoe
Air Conditioning
Jul 8, 2015 09:49 AM
