Help with Passenger Window
Old Jan 28, 2006
Crazylegs's Avatar
Crazylegs is an unknown quantity at this point
I bought a used 2002 Civic SI (Canada) coupe a couple of weeks ago. Both the drivers and passenger power windows worked at the time. Yesterday as I driving with a friend, he tried to put down the passenger window and nothing happens. I have checked the switch connections, the window lock and the fuses but no go. The drivers window works perfectly. Since I got the car I have put in an aftermarket remote starter/alarm and have had both door panels off to change the speakers myself. I've read about a dozen posts on the forum but no one has had the same problem or if they did it was the window lock or something. Any help would be greatly appreciated.
Old Jan 28, 2006
CraigW's Avatar
If you need the wiring info for the windows PM with E-Mail address.
Old Jan 28, 2006
streetglower's Avatar
can you roll the passenger side window down with the drivers switch?
Can you roll it down with the passengers switch?
If neither driver or passenger switch roll it down, then its not a bad switch. If one does, then its a bad switch.
otherwise, you have a faulty window motor, regulator, or fuse.
Old Jan 30, 2006
Crazylegs's Avatar
I can't roll it down with either switch and when I hit either button, absolutely nothing happens. No noises, sounds, etc. Which leads me to believe that it is either the window motor or regulator since I have checked the fuses and connections. Thanks.
Old Jan 30, 2006
Crazylegs's Avatar
Just a quick update:
I hooked up the old voltage meter to both the drivers and passenger side window controls and there is power running to both. So, I guess that only confirms that the problem is more than likely the motor on the passenger window. Thanks.
Old Jan 31, 2006
Crazylegs's Avatar
Update and Question:
I have now run a battery power test (as per the service manual) to the power window motor connector and got nothing. So since the switch tested ok and the motor does not, I'm guessing that the motor is shot. Or the regulator but since they come as a package then it doesn't really matter.
My question is whether or not anyone has tackled replacing their power window motor before? I couldn't find a DIY on the subject and the car is not covered under warranty. Does it involve removing the glass? Thanks.
Old Jan 31, 2006
it isnt that hard to do. you remove the door panel, then remove the window glass by removing the 2 or however many bolts connects the glass to the regulator, then remove the regulator assembly. usually held on by several bolts. then put it all back together.
Old Jan 31, 2006
CraigW's Avatar
I sent the single page on the replacement procedure to your E-Mail.
Old Oct 17, 2016
jewlz40's Avatar
jewlz40 is an unknown quantity at this point
Re: Help with Passenger Window
cant get power to front passenger regulator to replace broken window
can i manually lower it some how? 2001 Honda Civic sedan ex
just want the darn window in for now . will pay to find short when finances allow
Old Oct 17, 2016
jewlz40's Avatar
tested the switches not the problem, something keeps causing the passenger window fuse 22 to blow when key is turned on 2001 civic honda ex. help why is this happening? have new regulator and new switch for window, and a new window. cant install window cause cant drop the regulator enough. all others work fine individually and on main drivers door switches.
Old Oct 17, 2016
CraigW's Avatar
To fix the window the tech could isolate that windows motor wires, and provide jumped voltage from battery to the isolated motor leads to lower it down.
Blown fuse.... you have a constant short circuit.
wingsfan19
Oct 1, 2015 03:45 AM
Sep 27, 2015 11:33 AM
Dave Brabant
Sep 9, 2015 08:11 PM
Wiggles
Sep 8, 2015 05:05 PM
rainman15
Sep 6, 2015 11:10 AM
