HUrricane wilma and HYDROLOCK
Old Nov 2, 2005
tjboca's Avatar
tjboca is an unknown quantity at this point
Unhappy HUrricane wilma and HYDROLOCK
so i have a cold air intake on my car and yesterday i was drving...like normal except there was a bunch of water ahead normally i would just stop and look for another way around but i decided to truck on and go through it.(since it took me 1 hr when it normally takes me 15 minutes to get to my destination) bad mistake cause of course it sucked up some water adn i belive now my engine is hydrolocked..i wont even turn over nothign just sounds like its goign to start and thats it...my question is what to do with the damn car..put the stock airbox in. leave the cai in. brign it to the dealer. try insurance. pay for it...try fix it myself?? any suggestions please....
Old Nov 2, 2005
stl01civic's Avatar
BOOSTED DOHC i-VTEC
stl01civic is an unknown quantity at this point
dealer won't fix and even if u put back stock box on they will know.
Just go buy another D17. they are pretty cheap about $600-700.
Old Nov 2, 2005
Pocketace's Avatar
Pocketace is an unknown quantity at this point
You can fix this yourself. Just pull the plugs and turn the engine over using normal starting procedures. It obviously will not run without plugs but this will get the water out from the engine. After this is done, put the plugs back in and try to start it. It should run, there may be water in the exhaust so let the engine run a bit. Your last step is to go to your dealer or another auto shop and have a compression check done. If any of the cylinders is low it usually means you bent a rod. Just get that rod replaced or you will throw it and ruin your engine. If you have any questions pm me. I have been through this scenario with my offroading vehicle.
Old Nov 2, 2005
Jrfish007's Avatar
Yup he's right. The other thing is to change the oil ASAP, you probably got water in the oil and that's bad.
I bought a flood damaged car once, I bought a cheapo funnel like an oil one but metal and blew hot air down into it (use a hair dryer) and keep it each cylnder for a few minutes. I did this on and off for a few days, changed the oil, made sure the electric stuff was all good, and it fired right up.
Good luck and hope this helps.
Old Nov 2, 2005
CTICE's Avatar
CTICE is an unknown quantity at this point
I hydrolocked my engine a few months ago. They say I sucked up about a gallon of water and bent the rod so bad it wouldnt turn over even without the plugs in. They showed me the rod and it looked like a L instead of being straight. The bill was $2200, but the insurance company picked it up because it happened in a flash flood.
Old Nov 3, 2005
tjboca's Avatar
so yea my car got towed to a local shop..rods and everythign are fine..just alot of water and water in the oil..so yea basically im happy its nto goign to be expencive... and insurance dosent have to be involved
Old Nov 4, 2005
mradam85's Avatar
mradam85 should not be trustedmradam85 should not be trustedmradam85 should not be trusted
rods and cranks bend easy when you suck in water
aziankid1015
Jan 8, 2004 11:54 PM
NoToRiOuSxPiNoY
Aug 26, 2003 07:36 PM
DaPipeLayer
Jul 18, 2003 04:46 AM
jpan_home
18
May 6, 2003 09:59 AM
