Electrical Post information/questions/Issues about Electric parts here.
Ignition mystery
Old Jan 16, 2021
silverfootball's Avatar
silverfootball is an unknown quantity at this point
Ignition mystery
2010 Civic LX, When the engine is cold I have to hold the ignition key for a full minute or more before starter engages. After it warms up, everything is fine. I can shut it off and as long as I dont allow it to cool off it starts up normal.
Old Jan 16, 2021
Re: Ignition mystery
loose connectors?
Old Jan 19, 2021
Yeah, thats the first thing I checked, connections all good, Battery good
Old Jan 19, 2021
steering column included? could be inside the ignition
this type of stuff... Simply requires opening things up to find culprit
and no, we don't hear that happening. At the least, first time i hear it happening
Old Jan 19, 2021
Is it hold for a full minute and it cranks then it fires? Or hold for a full minute, then the starter starts to crank then fires?
Old Sep 11, 2022
Cad18's Avatar
Cad18 is an unknown quantity at this point
hi did you ever figure out what this was. Going through the same thing. Thanks
Old Nov 21, 2022
Vilmee's Avatar
Vilmee is an unknown quantity at this point
I'm having having the same issue.. is cold weather 24° .. every morning I have to hold the key 🔑 about a minute to get a crank and it starts .. after that it starts fine everytime.. if I stop using for about 6 hours it will do the same I have to hold the key for a minute again..
Old Nov 21, 2022
Vilmee's Avatar
is hold for a minute then starterer cranks and fires right away
Old Nov 22, 2022
Cad18's Avatar
Mine was doing this. I replaced the starter and took care of it. I think it is the solenoid on the starter that is causing this. Takes about 2.5 hours to replace the starter. Some people make a big job out of it on the civics but it's not that bad if you're patient and have nice set of extensions.
Old Nov 28, 2022
8th9thGenOwner's Avatar
8th9thGenOwner is an unknown quantity at this point
same for me. It got progressively worse until the day it wouldn’t start at all. My ‘08 civic needed to have the front axle taken off to replace it
Old Apr 19, 2023
Vilmee's Avatar
. It was the starter.. Problem solved
Thank You Cad
StudebakerJim
May 28, 2014 11:30 PM
runner1738
Apr 29, 2005 05:00 PM
turboslug
Jun 24, 2004 07:36 PM
STang57
Jul 15, 2002 04:56 AM
