Electrical Post information/questions/Issues about Electric parts here.
Break lights always on
Old Sep 10, 2019
Jmacmillan's Avatar
Jmacmillan is an unknown quantity at this point
2007 Civic ex, with break fuse in, the break lights are always on but don't get brighter when hitting the pedal and so are my head lights. The left blinker always stays on also. When I use the left blinker, it barley flickers. When I take the fuse out. The lights all work as they should? Has anyone ran into this problem before
Old Sep 10, 2019
Re: Break lights always on
headlights are always on, too? Might be purely coincidental.
At least for the brake lights, check your brake switch. If you look at your brake pedal and follow the arm up to the pivot point, you'll see the brake switch set into the bracket (#3 in the diagram below). If you have a multimeter, check if the circuit is closed when no pressure is applied to the button.
Old Sep 15, 2019
Jmacmillan's Avatar
I switched out the break switch but nothing. Replaced interior fuse box also.
TiggerDX
Jun 18, 2015 01:43 PM
noslot
Lighting
Jun 21, 2014 12:08 PM
angelmar06
Oct 14, 2012 09:06 AM
nvrmore
Buy, Sell, & Trade - Archive
Apr 8, 2009 05:23 PM
lapchern
Jun 12, 2006 07:51 PM
