Manual Trans rebuilt will not move the car
Old Feb 16, 2022
GBL's Avatar
GBL
GBL is an unknown quantity at this point
2007 Civic Si Coupe. 6 speed manual trans.
Rebuilt the 6 speed K series trans. Was moving the back and forth about 40 feet. Pulled on the street and will not move. No drive to the wheels. Can shift into in any gear without pressing the clutch. Can push/move by hand the car while in 1st gear. No grinding except reverse.
Replaced
Synchros
Bearings
4th gear set
2-3 gear hub
Seals
Welded/filed the wear spots on the shift forks.
Prior owner ran trans dry. 198000 miles before rebuild. Was driveable before tear down but had noise in 4th and popped out of 5th.
Old Feb 16, 2022
Re: Manual Trans rebuilt will move the car
2007 is not a 10th gen, moved to correct section.
Did an axle pop out?
Old Feb 17, 2022
BrotatoChip's Avatar
Super Moderator
Re: Manual Trans rebuilt will not move the car
My first guess would be popped out axle as well.
Old Feb 21, 2022
dagon007's Avatar
dagon007 is an unknown quantity at this point
and just how do you tell if there poped out whats the sign
Old Feb 21, 2022
FRSam's Avatar
Click Here
One sign is that when the car is in gear and the clutch is engaged, the car will not move, but this can indicate a few other things as well.
You'll have to inspect. Remove the hub assembly and see if one of the axles have popped out. There are lots of YouTube videos that show how to access.
Old Feb 21, 2022
shove it all the way to the hilt
Daniel Fountain
Transmission
Apr 5, 2021 06:30 AM
turbo_96awd
Mar 29, 2016 05:27 PM
dan1988
Oct 21, 2013 12:41 PM
huebenthal
Jan 21, 2012 08:05 PM
hircc02civic
Feb 1, 2005 02:44 AM
