HELP!manual trans wont shift left or right, stuck in nu,3,4 gear
Old Oct 21, 2011
turbo_96awd's Avatar
turbo_96awd is an unknown quantity at this point
I just did a trans swap for a guy with a 2001 civic with a 1.6 vtec. His told me the old trans made alot of bearing noise and was hard to shift in to 3-5+ reverse. (just back ground story) I started tearing her out and right away I noticed the motor and trans was covered in oil. This made a fairly clean swap very dirty. When I got the trans out I noticed that the trans housing was cracked on the front side. That is why all the oil is everywhere, and why the bearings where noisy and hard to shift. Well I put in the trans he brought with ( a rebuild he bought off someone). I went to drive it and I live on a country road so I drove up into 1,2,3,4 gears and when I went to down shift I couldnt move the shifter to the left into the 1st and 2nd gear bank or to the right 5th and reverse bank. I ended up driving the car back to my house in 3rd and 4th only. It goes into 3rd and 4th great just wont move side to side. When I got back I popped the hood and had a friend try shifting it and it seems the "#9 lever comp, shift" (referring to the link attached) doesnt move up and down like it should. I puller the shifter cables off and tried to pull and push the "lever comp" but it didnt budge. I searched and searched and cant seem to find anything that helped me. Can I just pull it out and swap it with the one from the old trans? Please any info will help. Thank you anyone in advance.
http://www.hondaoriginalparts.com/ho...block_03=13120
Old Oct 21, 2011
Re: HELP!manual trans wont shift left or right, stuck in nu,3,4 gear
Nobody knows anything?
Old Oct 22, 2011
Thank god the dsm forums arent like this, my car would never run.
Old Oct 22, 2011
lazlong's Avatar
It should move. Something in the tranny is locked up. Time for a rebuild.
Old Oct 22, 2011
MelJ's Avatar
Trance Addict
Then maybe you should go back to the DSM forums? Just because we don't answer a post immediately doesn't mean we're being jerks. We have lives and the most helpful members on here post every day or every other day. You could have a linkage issue. But a rebuild may be in order.
Old Oct 22, 2011
anibis's Avatar
anibis will become famous soon enoughanibis will become famous soon enough
There's a million civic forums so everyone is spread out.
Not everyone knows the insides of transmissions well, including me!
Old Oct 23, 2011
I am not putting anyone down. It was just at that time I have 58 people to have viewed my post and not one reply. The trans is suppose to be a fresh rebuild. It has been opened recently since there is fresh rtv on the case seems.
Old Mar 29, 2016
sim.ponz's Avatar
sim.ponz is an unknown quantity at this point
I'm having the same problem. Wish some one can tell me what it is
Flipg123
May 8, 2015 01:15 PM
oneheadlight
Apr 29, 2015 11:30 PM
davidpaustin
Apr 29, 2015 02:23 PM
dret
Canada West
Jan 8, 2002 03:05 PM
Russps
Nov 8, 2001 02:00 AM
