Help clearing code P0522 low oil pressure and limp mode
Old Apr 7, 2023
rwbriley's Avatar
rwbriley is an unknown quantity at this point
I have a 2011 Civic EX. 1.8. Non-VTEC. The CEL light is on and it has code P0522 for low oil pressure signal. It is in limp mode and sputters above 3,500 rpm.
I have replaced the oil pressure sensor on the front of the engine block. It made no difference. I have tested the sensor and there is continuity. I have 12 volts at the wire to the sensor. I have also put a remote oil pressure gauge on it and it has about 90 psi of oil pressure.
Every time I clear the code is comes right back on whether I have started the car or not.
Any suggestions would be appreciated. This is actually my daughter’s car. I am new to this forum and would like to say thanks in advance.
Old Apr 7, 2023
Re: Help clearing code P0522 low oil pressure and limp mode
have you put some oil in it?
Old Apr 8, 2023
rwbriley's Avatar
Thanks. It has plenty of oil.
Old Mar 1, 2025
davidsustr's Avatar
davidsustr is an unknown quantity at this point
Hi please, i have this same problem, Sensor is new bit no change
hcivic86
Dec 3, 2011 03:19 PM
GY58
May 30, 2010 07:54 AM
02CivicRider
Feb 14, 2005 07:22 PM
Goku
Jan 22, 2004 07:52 PM
Goku
Jan 21, 2004 04:45 AM
