Sway bar end link
Old Apr 4, 2021
Bobfrazier5526's Avatar
Bobfrazier5526 is an unknown quantity at this point
Sway bar end link
Okay so today I frigates I would start the task of replacing my front right sway bar end link. I tried to first remove it but using a 14 mm wrench and a Allen key to try to break the bolt loose. I tried soaking it in penetrating oil. I tried using vice grips to hold it still. Nothing, I got a saw zaw and tried to cut the bolt. This is my first time using a saw zaw and it took almost 40 minutes to cut half way through. Is this normal? I was using a 14 tpi metal cutting blade form Canadian tire. Should I invest in a better blade like a Diablo or Milwaukee torch blade? Thanks in advance
Old Apr 5, 2021
BrotatoChip's Avatar
Super Moderator
Re: Sway bar end link
I usually don't even try to undo the nut on those. I just grab my angle grinder with a cut off disk and cut the nut off.
Only used a sawzall a handful of times but I remember it taking a good amount of time to cut through some 1/2" rebar (5-10 minutes). I would guess the blade is already dull and is no longer cutting well.
Old Apr 5, 2021
Colin42's Avatar
Get a grinder and a zip disk. Or better blades
Old Apr 5, 2021
I don’t currently have access to a angle grinder. I’ll probably go and buy a Diablo metal cutting blade cause the ones I’m using burn out pretty quick
Old Apr 5, 2021
I went looking in the basement a found a dremel. Will I be able to cut a blot with the dremel ? What blade would I need ? My hardware store just has regular metal cutting dremel blades will those work
Old Apr 5, 2021
Super Moderator
You would need some sort of cut off disk. It may not have enough reach to go all the way through but you could make it work with enough disks and time.
You can get an angle grinder from Harbor Freight for like $20 plus some cheap 40 grit cut off disks. That's what I use and it's works just fine for sway bar links.
Old Apr 5, 2021
i actually bought that exact disk. It worked great cut through the bolt in a minute. Way better than a saw zall. I actually live in Canada so I don’t have a harbour freight here but I’ve always wanted to check them out next time I’m in the US
Old Apr 5, 2021
Colin42's Avatar
Princess auto is the same as harbour freight
Old Apr 6, 2021
Super Moderator
Originally Posted by Bobfrazier5526
harbour freight
Originally Posted by Colin42
harbour freight
Get rid of that 'U', this is 'Merica
Old Apr 6, 2021
Colin42's Avatar
Not our fault you guys can't spell properly
stevelaw18
Jun 13, 2011 08:04 AM
IronFist
24
Oct 6, 2007 07:28 PM
streetglower
Dec 13, 2004 08:50 PM
coolness5545
Jan 15, 2003 09:44 PM
01IncaPearl
May 24, 2002 10:58 AM
