Problem With OEM Sway Bar End Links, Help!!!
Old Dec 13, 2004
streetglower's Avatar
Last night I was removing my aftermarket exhaust which was welded on and after removing all the hangers, I then realized it was welded on and I tried pulling it through the back, but the sway bar was in the way, so I decided I would remove it. Well I started to remove the bolt on one side of the end link on the top, but it didnt come all the way off, it just kept spinning. Well after trying to tighten it back up, I still had the problem of the bolt spinning. So now I have a loose endlink because the top nut wont turn. When I try to tighten it, the hole bolt spins. There is a circle washer in the middle, do I need to hold that while I turn the bolt? I tryed doing that last night but nothing worked. What do you all suggest I do here? I know some of you have experience with the endlinks. I dont want to drive the car yet because of the loose endlink.
Old Dec 13, 2004
TeLLy's Avatar
Yes, it's an Acura EL
So did you use a 5mm Allen wrench in the slot right in the middle of the endlink nut? You have to hold a 5mm wrench in there while using a 14mm wrench to loosen/tighten the actual nut. Otherwise it'll just keep on spinning.
Old Dec 13, 2004
robbclark1's Avatar
Retired suspension supermod.
streetglower is a nooooooooooooob!! haha... j/k Haven't read the DIY on endlinks by Grey? Listen to Telly, he is a smart dude, even if he owns an acura
Old Dec 13, 2004
Shlomo's Avatar
Shlomo is an unknown quantity at this point
yeah, a 5mm allen key should work. if it doesn't use a something to hold that washer down while you turn the nut. thats what i had to do when swapping sway bars.
Old Dec 13, 2004
ojay's Avatar
ojay is on a distinguished road
be careful not to strip the allen key part...
Old Dec 13, 2004
ok thanks telly. I finally got it tonight.
Dorval Andre
May 1, 2015 09:37 AM
bsmiley
Apr 27, 2015 01:27 PM
zcwagon
Apr 24, 2015 05:18 PM
Firefly
Nov 28, 2001 06:13 PM
jessepimpride
Nov 13, 2001 05:59 PM
