19mm Rear Sway bar comment, Please read.
Old May 23, 2002
01IncaPearl's Avatar
01IncaPearl is an unknown quantity at this point
I searched and found that this had not been mentioned before. If you are planning on doing this upgrade you do not need to cut the bolt off if the whole thing turns when you are trying to take the nut off. There is a hole in the end of the bolt that fits a 5mm alan wrench. Just use a 14mm wrench and a 5mm alan wrench and it will come off with no problems. I know there was at least one person that acutally cut the bolt off and I would hate to see other people do that when it is not necessary.
Old May 23, 2002
SoNiCcIvIc's Avatar
SoNiCcIvIc is an unknown quantity at this point
Vewwwy useful Mista 01IncaPearl
Old May 23, 2002
<< Vewwwy useful Mista 01IncaPearl >>
twwanky you vwery much.
Old May 23, 2002
3rdcivic's Avatar
3rdcivic is an unknown quantity at this point
Geeeez, someone cut the bolt off? That's crazy! So, Inca how do you like the 19mm Sway-Bar? I installed mine and feel a little difference. It's kind of hard to tell since I put the Koni shocks on at the same time.
TJ
Old May 23, 2002
I felt a dramatic difference in how the car corners. My car takes corners much flatter now. Much better IMO.
Old May 24, 2002
Crashoveride's Avatar
Crashoveride is an unknown quantity at this point
Are you talking about the RSX sway bar swap, cause I was looking at getting it but wasnt sure if it would do anything since I have no suspension mods yet.
Old May 24, 2002
<< Are you talking about the RSX sway bar swap, cause I was looking at getting it but wasnt sure if it would do anything since I have no suspension mods yet. >>
yes, RSX type S sway bar
juror
Suspension DIY
Jul 30, 2019 03:28 AM
GotSiR
Jun 23, 2016 04:06 PM
OptimisticWay
46
Oct 15, 2015 02:16 PM
protoCall7
Bolt-on Engine Performance
Jul 26, 2015 07:41 PM
fordover
Jul 11, 2015 09:10 PM
