New leak after oil pan [solved]
Old Jul 26, 2022
crajnai's Avatar
7th Gen Victim
crajnai has a spectacular aura aboutcrajnai has a spectacular aura about
So I took off and replaced the oil pan following the directions in an old thread. I now developed a trans fluid leak. After it’s hot and off a steady slow drip happens near the trans shift cable housing, which had to be removed to get off the oil pan.
Is there a gasket or O ring in this vicinity someplace I may have missed or some sealant that needs to be reapplied? I find it VERY odd to go from no leak to a steady drip without even touching the trans. Was there an o ring on the shift lever? I dont remember seeing one.
yes the dipstick is in all the way and the coolant hoses are fine. I cleaned everything on top and nothing is bad. It’s only showing underneath at the shift cable housings and a little on the flat part of the trans.
EDIT: it’s oil not trans fluid.
Dang Hondabond job didn’t work out. Got a fresh tube.
I read in the manual to apply the goo to the block, but getting it up in there by the torque converter is not so easy, and that’s where it looks like it failed.
any pointers are welcome.
Last edited by sdaidoji; Jul 26, 2022 at 09:18 PM. Reason: brought back the deleted parts, it's easier to understand with it still there
Old Jul 26, 2022
Colin42's Avatar
re: New leak after oil pan [solved]
I put it on the pan
Old Jul 26, 2022
crajnai's Avatar
7th Gen Victim
Ya seems like a better approach Colin.
FYI I asked the shop how much to get it done. $300. A tube of Hondabond was $25
Old Sep 18, 2022
crajnai's Avatar
7th Gen Victim
I put it on the pan. Seems ok and easier that way. If I have to do it again I suspect it would be smart to let the pan set overnight while the Hondabond set, and THEN redo the pan brackets. Those brackets have close tolerance which seems to compress the Hondabond a little more than I would like.
The weakest spot is the ring around the rear main seal. Really hard to clean in there and to put just the right amount of pressure to set the goo.
77Spitfire67Mg
Dec 10, 2022 07:16 AM
redlion4
Dec 13, 2020 12:18 PM
lindylex
Dec 19, 2019 04:59 PM
the dutchmen
Feb 5, 2017 05:06 PM
Execut1ve
Feb 5, 2012 08:42 PM
