Installing countershaft & needle bearing; Did I do it right?
Old Feb 8, 2019
elfred's Avatar
elfred is an unknown quantity at this point
Hi Civicforum,
So I am doing a M/T rebuild because of the ISB issue, might as well rebuild the other bearing.
The first photo is the OEM bearing on both countershaft, before I take it off, needle bearing clearance has little bit millimeter gap on it on the gear.
So second photos is when I installed new countershaft and needle bearings.
My question is, did I do it right on needle bearing (the 2nd one on the latter that touches the gear so much) will it scratched on the gear, do I need to worry about it? And is there any peeler gauge measurement when doing this?
Cheers!
Elfred
Old Feb 8, 2019
Re: Installing countershaft & needle bearing; Did I do it right?
What does your service manual say?
Old Feb 8, 2019
elfred's Avatar
I dont have manual book for Acura 2001 EL 1.7, just bought this car few months ago.
Old Feb 8, 2019
Search forum for "looking for a 7th gen manual for free" and go to the most recent pages and links in the thread
Note most links lead to manuals that cover cars worldwide so be careful when looking for info make sure it really applies to your own car
Old Feb 8, 2019
elfred's Avatar
Ok awesome!, thank you! I got the link;
downloaded it and seen lots lots!
still checkin on it on my smart phone...
https://www.civicforums.com/forums/1...pdated-10.html
Thanks again dude!
Old Feb 9, 2019
elfred's Avatar
Hi civicforums! so just on update on my CS bearing and clearances.
took some photos if my spare tranny(left), seems looks the same how I install it.
Cheers!
ELfred
Old Feb 9, 2019
That bearing you mentioned earlier you said rubbed against the gear (" will it scratched on the gear, do I need to worry about it? "), it should not do that.
(fails a very basic rule of thumb: "is there enough clearance?") The race must be far enough away to not rub as the gear spins
But You needed to be using a real service manual anyway, hope that helped
I could not tell if maybe something got assembled upside down (a very real possibility) but that might be enough to cause a clearance issue like that
Old Feb 10, 2019
elfred's Avatar
Ok Im not sure if I did it upside down, I might pull it gently, and re-install it again...
but using bearing puller will make this new installed bearing garbage,
I am thingking by pulling it to the shaft, I might drop the shaft to the ground upside down,
so only inner race on both CS bearing and needle bearing will move fair enough equally out
from the counter shaft to avoid bearing deformity.
Elfred
Old Feb 10, 2019
elfred's Avatar
The inner needle bearing has a clearance, the only worries me is the casing of the inner bearing the one that rubs on the top latter of the splined fixed gear.
photos here as disassembled before installing.
indynic
Transmission
Sep 23, 2016 02:13 PM
kellogg6316
Aug 31, 2016 12:59 PM
lame05
Transmission DIY
Sep 8, 2013 02:25 PM
judas009
Oct 1, 2012 09:18 PM
Nickerz
Jun 20, 2007 06:21 PM
