2006 Civic LX Manual Input Shaft Bearing
Old Aug 1, 2014
indynic's Avatar
indynic is an unknown quantity at this point
I did a search and could not come up with anything for 8th gen. I found a lot of talk about 7th gen input shaft bearing issues.
I believe that the input shaft bearing is going bad on my car. It does not make any noise in neutral yet, but it has a "growling" noise in the first three gears during acceleration. Car has 136k miles on it.
Have there been a lot of issues with the transmission bearings on the 8th gen?
I am going to try to pull the transmission and replace the bearing. I am going to go ahead and install a new clutch, throwout bearing and pilot bushing while I am at it.
Should I change the rear main seal while I'm at it?
Are there any "how to's" already out there for this stuff?
Any input will be appreciated.
Thanks.
Old Aug 1, 2014
speedy25's Avatar
speedy25 is an unknown quantity at this point
Re: 2006 Civic LX Manual Input Shaft Bearing
Since you will have the trans out replace rear crank seal and input shaft seal. last clutch job I did I wasnt thinking and forgot the seal on the trans. Yep it gooped up my clutch and caused it to slip.
I hope your bearing can be replaced from the front.
-SP
Old Aug 1, 2014
I personally have not had to do any 8th gen ISB work as of yet, but I'm in a small dealer and we have very few customers with manual trans cars here.
I think the rear main seals have been reliable enough to not be a concern to me unless there is already evidence of a problem.
Old Aug 18, 2014
indynic's Avatar
Update:
I pulled the manual 5 speed transmission and replaced the input shaft bearing. I replaced the clutch, pressure plate, pilot bushing and throwout bearing as well.
The original input shaft bearing was worn out for sure. Looks like this generation civic manual transmission is not any better on input shaft bearings than previous generation civics.
Other parts in the transmission looked brand new. Almost no metal shavings on the magnet whatsoever. Gears were perfect, which they should be. I can count on one hand how many times I have missed a shift and I bought the car brand new, so no one else has driven it.
I left the rear main seal alone because there were no sign of leaks.
Hopefully, this input shaft bearing lasts another 136k. I don't really want to have to do that job again. It took me 10 hours to complete start to finish.
Old Sep 23, 2016
Mattymatt716's Avatar
Mattymatt716 is an unknown quantity at this point
Hey Indynic- I pm'd you. ISB part #? And, is it significantly different than the 7th gen transmission? I need to get this done ASAP.
Xuhme
21
Aug 7, 2023 03:40 PM
bsmiley
Apr 27, 2015 01:27 PM
C6GrandSport
Apr 25, 2015 09:41 PM
chirp the 1-2
Apr 19, 2015 02:19 PM
Myredjonda
Apr 14, 2015 07:00 PM
