transmission codes
Old Feb 12, 2019
tyguy764's Avatar
tyguy764 is an unknown quantity at this point
transmission codes
hi my 2002 civic and drives fine got 145k on it i have two codes p1705 an p0740 would the p1705 code cause p0740?
Old Feb 14, 2019
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
Re: transmission codes
The P1705 is a Short in the Transmission Range Switch Circuit and is an electrical issue and not mechanical. Did you play around with this harness when you were troubleshooting your stalling issues a few days ago? You will need to check the circuit for a short, open wire, poor connection or ground or bad range switch or PCM for this code.
The P0740 is a Lock Up Control code and is not a good one to have. Basically internal fluid pressures are not shifting the trans anymore. Most likely clutch debris clogging the internal ATF filter or solenoids or orifices. Recommended ATF maintenance is a normal drain and fill of Honda DW-1 every 3rd oil change at least. What has been the ATF maintenance? Never power flush.
Old Feb 14, 2019
Troubleshoot and fix the P1705 code first (the computer probably detected more than one range switch input at the same time).
After that is corrected then drive it and see if P0740 sets again.
torontob
Transmission
36
Sep 14, 2020 08:17 AM
Greenhawk22
Transmission
Aug 15, 2019 05:58 PM
kevoid
Transmission
Oct 20, 2018 03:33 PM
BrettC
Jun 21, 2016 07:53 AM
malcolm2
Jun 30, 2014 12:22 PM
