P0848 code - 3rd clutch trans pressure switch
Old Jul 14, 2019
Greenhawk22's Avatar
Greenhawk22 is an unknown quantity at this point
I've changed the trans fluid, with genuine Honda fluid, and replaced the switch, yet the code persists. The car is still driving fine though, with no noticeable change in the shifting, etc. However, I want it gone, as it's very concerning. That said, any advice on where to look next? When the code popped up, my radar detector suddenly went off and said "service required", so perhaps there was some sort of electrical surge. If so, could this have damaged the PCM? Any advice would be much appreciated.
Old Aug 14, 2019
ugiles's Avatar
ugiles is an unknown quantity at this point
Re: P0848 code - 3rd clutch trans pressure switch
Have you had the DTC code reset? If not, that's the 1st thing I would suggest. If it doesn't come back then you're fine. If it does, then use a multimeter to check the DC voltage between the connector at the sensor and the body ground. If there is 5 or so Volts, then the fluid pressure switch is bad and needs replaced.
Old Aug 15, 2019
Codes can be reset by just unhooking the battery for a bit, correct? If so, yes I've done this and the shifter light does then go off, but comes back on within 2 minutes of driving.
Also, as I've said, I already replaced the fluid pressure switch.......
Old Aug 15, 2019
Colin42's Avatar
did you use an oem part?
roverben
Transmission
55
Sep 3, 2025 02:50 PM
torontob
Transmission
36
Sep 14, 2020 08:17 AM
sierrawindy
Transmission
Feb 24, 2018 05:31 PM
kingholdem87
Aug 26, 2014 08:19 AM
walshkr
Jul 1, 2014 05:33 PM
