OBD2 code 1706
OBD2 code 1706
I see a few posts about the open Tranny range circuit. Lot's say what the switch does.... BUT why did it throw a code. My son drives this car and I am lucky if I can get him to put gas in it, so I have no idea if the car is acting funny.
Would you feel a shifting problem? Maybe it runs up to 3rd and never makes 4th, kinda thing? Any other symptoms? Would it throw a code if it was just a hiccup and only happened once, or 1 code = bad switch?
Thanks
Thanks
Re: OBD2 code 1706
so I picked a random 7th gen car.01 Civic with Auto trans (not CVT)
P1706: Open in trans range switch circuit
What if a mouse chewed the wires?
HTH
Re: OBD2 code 1706
You didn't tell what specific car you are dealing with
The computer saw: The FWD switch is (or was) open circuit during acceleration/deceleration.
HellifIknow. Does it really matter? If the kid is an average appliance user, he might not understand anything is wrong until the car can no longer pull itself down the road under its own power.
I don't really know of any codes defined as "replace part".
HTH
HTH
Yes, 01 civic.
I don't follow your "defined as replace part" comment.
The part is the switch, how else do you get the code repaired.
Anyway, I have cleared the codes with the code reader, and will wait to see if they come back. And I'll keep searching I guess.
*watches temp gauge like a hawkboss* :D
Re: OBD2 code 1706
His point was that codes are only what the PCM is programmed to report; it's not a substitute for going in and looking at the whole system and using hands-on diagnosis. You didn't read his 'mouse chewed wires' comment... the same code can be thrown for bad wiring -- you replace that switch, and the code will still come up if the wires are open.
Re: OBD2 code 1706
Code P1706 is not defined as "replace range switch".
The description (definition) of the code P1706 is "Open in trans range switch circuit" That includes everything from the switch to the PCM, and maybe more.
Testing can verify or eliminate likely and possible causes.
If a rodent chewed off some wires and codes were set because of that, do you think that replacing the switch would cure the code?
Although parts replacement may take care of many problems, it can't fix all possible problems. I deal with quite a bit of rodent damage in my area, and have been dealing with it for decades.
I learned very early in my career to test and verify before throwing parts at any problem, because throwing parts doesn't always solve the problem.
If the code stays gone for a while, it would probably have been caused by an intermittent switch issue.
If the code returns immediately, I'd expect either a bad switch or wiring. If the failure condition is present during testing, the true cause should be easy to determine.
HTH
HTH
Civic15
18
Sep 19, 2017 07:48 PM
Dangerousjordan
Jul 30, 2015 11:19 AM
jessica19699
Jul 29, 2015 05:51 AM
Green02civic
Jul 27, 2015 10:48 PM
