Overheating or loss of coolant, heater blowing cold If you are having overheating of loss of coolant issues, post here!
What gaskets do I need?
Old Dec 16, 2023
Robertlx's Avatar
Robertlx is an unknown quantity at this point
What gaskets will I need to change the thermostat and coolant temperature sensor? Where can I get the thermostat, gasket and sensor online for a reasonable price. Plus what temperature thermostat should I order (170°?) If possible can someone post an image of the gasket or gaskets?
Old Dec 16, 2023
Re: What gaskets do I need?
https://www.civicforums.com/forums/3...one-these.html
Old Dec 16, 2023
@sdaidoji ngl, your response led me to IAT stuff, not t-stat and coolant temp stuff.
OP, whatever thermostat you buy should have the necessary o-ring on it. Similarly, the switch should have the o-ring, as well. You shouldn't have to buy any extra gaskets, assuming that's all you're replacing.
If you want Honda OEM, the thermostat part number is 19301-PAA-306 (OEM spec is 170F) , and the coolant temp sensor is 37870-PLC-004
Old Dec 16, 2023
scroll down.
You will see that I already answered his question about where to get parts online in that thread not so long ago (they are from same poster)
Old Dec 16, 2023
Robertlx's Avatar
Originally Posted by sdaidoji
scroll down.
I just wanted to make sure that I didn't need the whole housing gasket..the thermostat separates from the main housing.. one small round gasket needed. Thanks
mwright4264
Nov 24, 2022 08:29 AM
mhammond1127
Apr 3, 2018 01:47 AM
BotenRedWolf
Mar 9, 2013 01:55 PM
lame05
Nov 9, 2011 11:36 PM
specks
Mar 1, 2005 02:12 PM
