Engine rebuild
Old Sep 3, 2024
civigov's Avatar
civigov is an unknown quantity at this point
Engine rebuild
How’s it going guys. So I’ve been rebuilding my d17a vtec motor in my 01 civic, first time I put it back in I screwed up on the bearings. Had to pull motor out and redo it. Now that that’s all good, I put the motor back in and car would not crank or start. I pulled the engine harness with the motor, and now I hear a clicking coming from the orange fuse in the passenger glove box which is supposedly an ecu relay, I tried replacing it and it still isn’t working, any ideas? I’m thinking maybe I frayed a wire pulling the harness out of the firewall? Do you guys think I need a new harness ? Any help is greatly appreciated.
Old Sep 3, 2024
Re: Engine rebuild
check starter motor wires and connectors, first it need to crank
Old Sep 3, 2024
civigov's Avatar
Re: Engine rebuild
so yeah actually forgot to mention that I put a new starter as well because I thought maybe that was the problem. Do you think it could be a connection somewhere?
Old Sep 4, 2024
Re: Engine rebuild
if it is not cranking and the battery is good, then just directly fire the starter
Old Sep 4, 2024
BrotatoChip's Avatar
Super Moderator
Re: Engine rebuild
Could be explained by an almost dead battery after sitting to the side during rebuild. Make sure it's fully charged.
George4242
May 10, 2013 09:04 PM
funkybunch
Oct 17, 2012 10:01 PM
1992VX
Nov 20, 2011 12:29 AM
vwvanguy
Feb 1, 2010 10:42 PM
essire
Jul 28, 2009 07:42 AM
