Cost of tightening both fan belts
Old Jun 6, 2023
Robertlx's Avatar
Robertlx is an unknown quantity at this point
What roughly at a moderate shop is the cost of tightening both fan belts? -2005 Honda civic LX sedan
Old Jun 6, 2023
Re: Cost of tightening both fan belts
about 10-15 minutes with a 10mm socket
Shop will charge you shop rates, I'd venture a guess of 100/hr average, and charge you maybe a half hour if they pro-rate? Best bet is to call around since shop rates vary, but I'd venture a guess of 50-100?
Old Jun 6, 2023
Colin42's Avatar
Do it yourself
Old Jun 6, 2023
Robertlx's Avatar
Originally Posted by Colin42
Do it yourself
I didn't want to make an excuse because I'm 74&1/2.... But I don't have jacks or even know where the tighteners are. Back in the 50s and 60s it was the generator or alternator..so I'm not gonna guess ..lol..thanks
Old Jun 6, 2023
Do it yourself
I was thinking the same thing, then realized that not all people have the capability to DIY everything.
But.. if you're curious, this is where you adjust the belt tensions:
The power steering belt, the adjustment is the wing bolt right next to the belt
For the alternator belt (if you have AC, it piggybacks off this), its a bit more difficult to get to. There's a whole sliding bracket you have to loosen the left-right oriented bolt, then tighten/loosen the wingbolt to adjust tension. Looks like this pic was taken from the outboard side looking in. The left-right facing bolt has been removed, and the hole you see above that wing bolt is where it goes.
Old Jun 6, 2023
Robertlx's Avatar
So if that's all it takes to tighten it , then it shouldn't be too much money at the shop? Looks like a 5-10 minute job.
P.S.
While I'm here, that Cold Ram intake..how do you remove the MAF sensor to clean it? I see it sitting in my intake but wouldn't want to try to pry on it to clean it without instructions.
Old Jun 6, 2023
yeah, usually wouldn't be a super long job, but, we all know how some shops operate. It really is a 10 minute job without having to jack up the car or anything.
With regards to the MAF sensor you speak of, you able to snap a pic of what you're looking at? The 01-05 civics didn't have any flow (MAF) sensors, just a MAP sensor right on the top of the intake manifold, about 3 inches to the right of the throttle body (to the right when facing the engine)
Old Jun 10, 2023
Robertlx's Avatar
Don't mean to stall but the car's covered up. I'll will snap a pic of it. It's a long L shaped chrome tube with a cone filter on the end of it. Right where it turns 90 degrees is what looks like a sensor of some sort, so I guessed it to be a MAF
Old Jun 12, 2023
BrotatoChip's Avatar
Super Moderator
I am guessing it's an intake air temp sensor.
Old Jun 12, 2023
Robertlx's Avatar
Here.
As far as that blue bar or rack is, I couldn't explain.
Old Jun 12, 2023
Super Moderator
Large chrome tube is an aftermarket air intake. The sensor on the right is the air intake temperature sensor. The smaller blue tube running to the valve cover is the fresh air draw for the crankcase ventilation.
Old Jun 12, 2023
Robertlx's Avatar
Is there a MAF sensor. Can I clean the air intake sensor? If so how would I remove it?
Old Jun 12, 2023
wasn't that the MAP (or MAF) sensor in the intake?
I think that is painful to remove, if possible at all
Old Jun 12, 2023
Robertlx's Avatar
If anyone in the forum has seen something like this they could offer a suggestion. I guess most of these types of sensors come out the same way. I wouldn't know where to get a new one if I messed up.
Old Jun 12, 2023
This is the MAP sensor
The one sticking out the side of the intake tube is the intake air temp sensor (IAT)
Edit: to remove the IAT sensor, unplug it (to avoid damaging the wires) and give it a firm pull. Should come out. The rubber grommet might come out with it, but that's not a big deal. Prolly won't do you much if you clean it, but it also won't hurt anything.
The map sensor is held on by a screw and, same deal, firm pull upward. That shouldn't give you much issue, either. I remember spraying mine down with some brake cleaner and having no issues. Your mileage may vary.
Old Jun 12, 2023
Robertlx's Avatar
I have MAF cleaner in a spray can.
Old Jun 12, 2023
woah, sorry about my ignorance about that :P
next time, i will pull the ***** off when removing it
Old Jun 13, 2023
Colin42's Avatar
That will work fine
contevo
Jul 30, 2019 08:59 AM
chuckd83
Aug 22, 2010 06:31 PM
Demarini
Oct 5, 2009 01:17 PM
dru106
South Cali
46
Jun 18, 2008 11:09 AM
