Oil pump seal steps
Old Jan 22, 2023
crajnai's Avatar
7th Gen Victim
crajnai has a spectacular aura aboutcrajnai has a spectacular aura about
Oil pump seal steps
Seeking opinions. D17A2
Can I get the oil pump off without taking off the timing belt? Take off the pulley and bottom cover. Mark the belt. Get the tensioner in place, Shove it out of the way. Can I just Do the pump and not have to take the whole top of the engine apart?
Old Jan 23, 2023
BrotatoChip's Avatar
Super Moderator
Re: Oil pump seal steps
Service manual wants the belt removed. Can you even get to the tensioner without removing the engine mount? I thought it was completely covered underneath. I've never tried but I'm leaning towards it not being possible without at least removing the mount. That requires removing the alternator, which needs the PS pump out of the way. At that point you're half way there. All for a $2 O-ring
Old Jan 23, 2023
crajnai's Avatar
7th Gen Victim
Ok then. That mean I need to jack the engine up without a pan on it. Any suggestions on what surface to jack it upon that will not be in the way?
Old Jan 23, 2023
Colin42's Avatar
Throw the mount back on once you have all that stuff off.
Old Jan 23, 2023
Super Moderator
Can't remember if the subframe has to be dropped to get the oil pan off. If not, the other three mounts will keep the engine in just fine.
Old Jan 23, 2023
crajnai's Avatar
7th Gen Victim
Oy this is gonna be fun. Thanks folks.
Old Feb 6, 2023
crajnai's Avatar
7th Gen Victim
Did the job this weekend all good. I did not have to go as far as removing the engine Mount. The timing belt will be slack enough with a 6mm Allen and a little wiggling.
I documented the steps. gonna post them here for posterity. FYI 17lb torque is too much for the take up tube bolts. Broke that.
Old Feb 7, 2023
Super Moderator
Great write-up! Moved to it's own thread in the DIY section. Link below.
https://www.civicforums.com/forums/1...ent-steps.html
For reference, the torque spec for the oil pick up tube bolts/nuts is 7.2 lb-ft.
Old Feb 7, 2023
sorry, thought it was not a DIY and moved... moved back there...
lorenzoz
Jan 12, 2020 10:33 PM
Ohyaimember
Feb 28, 2017 06:52 PM
moorebl
Jul 29, 2014 10:01 PM
5ltrdrmr
Apr 13, 2014 06:32 PM
metfan53
Apr 20, 2012 11:16 PM
