Oil pump to block seal replacement steps
Old Feb 6, 2023
crajnai's Avatar
7th Gen Victim
crajnai has a spectacular aura aboutcrajnai has a spectacular aura about
Civic Oil seal job 7th gen automatic
Set out all sockets, flat screwdrivers, pliers, rags, washtubs and cleaners, sealant, notes, sharpie.
Rags and boxes on floor for parts as you go
New parts on separate table
Bag everything and label carefully.
Be gentle with wires.
Move quick don’t rush stay warm and fed.
Top engine off
Disconnect battery negative side.
Remove air cleaner and sensor wire, losen gasket to throttle body.
Remove harness and coils
Remove bracket under air cleaner
remove power steering pump and reservoir and belt
Loosen alternator and remove belt
Remove valve cover watch the helicoil on pass side
Cover cam assembly with plastic or foil
Remove top timing cover and cam sensor wire
Front engine off
Jack car kinda high. Block wheels. Set parking brake.
Remove front driver wheel and plastic wheel well crap
*Set engine and cam to TDC*
Remove crank pulley with special tool and breaker bars
Remove bottom timing cover and crank sensor
Retract belt tensioner as far as possible with 6mm Allen and set with a nail or bent coat hanger or whatever
Remove timing sprocket and woodruff key and washer and move timing belt outta the way.
Underside off
Dump oil
Remove exhaust oxygen sensor wires.
Remove exhaust pipe bolts.
Drop it to the floor and get it far aside.
Remove whatever hangs it up.
Remove pan girdle brackets, trans shift covers and cable and lock washer with a razor blade, remove nasty inspection cover. Check for oil splash.
Remove oil pan. Try and pry and cry.
Remove oil take up, screws on block and pump
Remove oil pump
Breathe. Smoke. Have a drink. Get a snack. Take a nap.
Clean clean clean
Using brake cleaner and goof off, plastic brush, and razor blades. (Gasoline/kerosene if necessary)
Clean pan mating surfaces
Clean oil pump and take up tube
**Remove crank seal ring from oil pump
Check pump sealing curve that mates with the oil pan for etch and Polish with superfine sandpaper if necessary
Clean front of block mating surface and timing belt and all around timing path
Clean bottom of block mating surface.
Clean valve cover and inspect/replace plug seals
Clean top of block mating surface of old sealant In corners
Clean timing belt and paths from any oils
Reassembly
Oil pump on
Replace oil pump o ring
Apply black sealer to oil pump mating surface and a little around o ring and reinstall 4 oil pump to block. Must align with crankshaft! , torque bolts to 9lb
Install take up tube gasket with a little black sealant and take up tube bolts to RFT.
Install take up bolts to engine RFT
Oil pan on
Apply black sealer and install oil pan:
Tighten the bolts in two or three steps. In the final step, tighten all bolts, in sequence, to 12 nm (8.7 lbf·ft).
Torque spec
Ft-lb
Oil pick up tube bolts..............................RFT
Oil Pump to engine block bolts/nuts...........9
Oil Pump Screen bolts..............................RFT
Oil pump cover Screws.............................RFT
Breathe. Smoke. Get a drink or snack.
Install inspection cover, trans shift cable, covers, and girdles. Torque to spec
Install exhaust bolts and attach pipe hanger
Replace whatever was hanging it up.
Install oxygen sensor wire
Timing on
Install crank seal, washer, sprocket and timing belt. Keep timing correct.
—-If necessary this is where you need to jack engine and remove the alternator and top engine bracket to loosen the spring and bolt on the tensioner. I did not have to. But if you do, Accept your fate and continue quickly
**check timing mark slot on sprocket to mark on oil pump to camshaft tdc**
Temp install crank pulley mark the bottom circle with white
***check timing 2 then another 2 revolutions counterclockwise until white mark is at center bottom and ensure cam is still TDC***
Remove crank pulley and inspect timing mark on sprocket for alignment. Reset and repeat if necessary.
Ensure torque on tensioner bolt 30lb
Pull the pin and/or replace spring to tension timing belt
—-if necessary reinstall the engine bracket and alternator now. Remove engine jack.
install crank sensor and bottom cover and wire
Install crank pulley with special tool
***Crankshaft bolt 14 lb and an additional 90°
Top engine on
Install top timing cover and cam sensor wire
Set gasket into valve cover
Put black sealant in corners and install valve cover
Beware of any helicoils
Valve cover bolts *center first, gently in stages until set light torque
Install air cleaner bracket
Install alternator belt and tension it and lock down mounting bolts
Install power steering and reservoir and belt and tension it
Install wiring harness and plug coils and throttle cables.
Install air cleaner
Final
Check under engine for all correct. Torque oil drain plug.
Install plastic wheel well crap
Install wheel and wheel lug nuts snug.
Jack it all down. Unblock wheels. Release parking brake. Torque lug nuts 80lb.
Have dinner. Drink. Smoke. Goto bed. Say your prayers.
Let all liquid gasket set 24 hours or at least overnight.
Fill with oil. Reconnect battery. Start it up and idle 10 min.
Shut it off.
Start it up again and shake it down.
crajnai
Feb 7, 2023 06:35 AM
craddmd
103
Aug 24, 2021 05:38 PM
metfan53
Apr 20, 2012 11:16 PM
pwnsauce
Feb 3, 2012 07:25 PM
2k3HonCivicEX
Detailing
Feb 18, 2004 12:30 AM
