Valve removal - quick instructions
Re: Valve Stem Seal Replacement
To remove them, I used a pair of ViseGrip groove lock pliers and a lot of "gentle" force and wiggling to get it off. I didn't find a way to take them off non-destructively, at least with regards to the valve seals. Just be careful not to damage the valve guide itself
To install them, I used my thumb and they clicked in place just fine. I didn't use any special tools for removal or installation
Re: Valve removal - quick instructions
I figured it out using the 9.99 valve seal plier from Amazon. What you have to do first is burn the seal with a torch or lighter until it starts smoking. Then use the pliers and it slips off easy.
Obamargarine
15
Feb 6, 2017 01:54 AM
