Cylinder misfire
Old Nov 1, 2019
  #31
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
Re: Cylinder misfire
All the bases are covered here for misfire codes: https://troubleshootmyvehicle.com/ho...isfire-codes-1
You should check your head gasket too as a breached HG is quite common in these engines.
Old Nov 1, 2019
  #32
Tracecross30's Avatar
Tracecross30 is an unknown quantity at this point
Ok..i read this link that you gave me before. I will check the fuel injectors before anything else and the fuel pump also. My head gasket is about 5 months on the car. The car is not over heating or anything so i dont think head gasket will causing that. Its felpro brand kind of head gasket is on there. Not sure if thats a good brand to use though..
Old Nov 1, 2019
  #33
BrotatoChip's Avatar
Super Moderator
OEM is always recommended. I wouldn't just assume it's the head gasket without hard evidence though.
Old Nov 2, 2019
  #34
I can smell the gas coming from the tailpipe just now. I have unstable fuel reading n my gas is not lasting either.
Old Dec 5, 2019
  #35
Its been awhile since i posted a thread about my misfiring problem. I'm still having the check engine light and the codes were there still until about 1:30pm today the check engine light went off so im not sure if it will comes on again because it happens before. I changed plugs,coils and fuel filter. I even did a compression test and i got 185 on each cylind except for cylinder #3 , its reading 180.. I didn't put any oil in the spark plug hole on that cylinder like the book recommend..
Old Dec 5, 2019
  #36
Marcelo Souza's Avatar
Marcelo Souza is an unknown quantity at this point
there are 2 types of compression tests if the compression is low you put oil in it and go it again and it goes up it is your piston rings if it doesn’t go up it’s one of your valves
Old Dec 5, 2019
  #37
I don’t remember the compression that that car is supposed to have but it doesn’t look like that’s to much of a deviation
Old Dec 5, 2019
  #38
Super Moderator
Service manual says minimum of 135 psi with a maximum variation between cylinders of 28 psi. You are well within spec. 185 psi sounds like a good number as well.
Old Dec 5, 2019
  #39
thank you all.i will try it again with the oil, but how much oil should i drop in the that particular cylinder thats low to do the next test?
Old Dec 6, 2019
  #40
Super Moderator
You do not need to do it again. Three cylinders at 185 psi and the fourth at 180 psi is totally healthy.
Old Dec 6, 2019
  #41
Its not cylinder 4 at 180,its cylinder 3 at 180 and all the others at 180, But ok.tge check engine light came back after started the car. I have a little rough idle from the codes came on for the misfiring..im the thinking of changing the injectors. To see if that will solve the problem?
Old Dec 6, 2019
  #42
Also,apart from the dealership, you have any idea of where i can the wires that goes to coil pack? I'm not finding anything online and i know that the dealership price is going to be high.
BrotatoChip, you i missed read your last text about the cylinder.i just go back and read it, my bad.
Old Dec 7, 2019
  #43
GolNat's Avatar
Prelude Owner
Junk yard is your best bet.
Old Dec 12, 2019
  #44
I was thinking that but i dont see where i can take apart the coil pack wires only...its a whole long bunch of wire together for injectors ,coil packs,sensors and other stuff.
Old Dec 12, 2019
  #45
Colin42's Avatar
Ever heard of splicing wires?
Old Dec 12, 2019
  #46
I can surely do that but, thats another thing because I'm not sure where the wire maybe bad..i can surely get the ends that goes to the coil packs online and splice them bro.
Old Dec 13, 2019
  #47
Colin42's Avatar
Maybe you should do more diagnosis and figure out what's actually wrong
Old Dec 13, 2019
  #48
True..i think i have a vacuum leak or my cat is bad because i have a code for cat too..and if the cat is bad it can cause it to be misfiring too.if i fix it i will post an update.
Old Dec 14, 2019
  #49
Hey man,i have an issue with my tranny. I was having a loud moise coming from my tranny and realized its the main shaft bearing thats bad so i was working on it lastnight through today.i take it off the engine,opened it up and change the bearing and the seal behind it also.i also change the 3 gear synchro as well as the spring.i put it back together and spend a few minutes checking the gears to make sure they are working fine until now when i started the car and it stuck in reverse.you have any idea what could c
Old Dec 23, 2019
  #50
So lets give an update on my issues that i was having with my cylinder misfiring from 1-4. I changed spark pugs,coil packs,fuel filter and nothing seem to change. I start the car one day and while its idling, i tried the method that guys use by unplugging the wires from the coil pack to see the difference the engine will made. I did that with injectors and i noticed the engine did made a difference on cylinder#1 but not much different on the rest of the cylinders so decided to change the injectors and i did replaced them today just after work and scanned the system again,to my surprise,the codes disappear only left codes for down stream o2 sensor and Idle air temp sensor. I erased all those codes,took the car for a 3-4 miles drive and everything seem to be working fine..no more rough idling with the engine nor steering vibration..thamks for all the advice from you guys.
and i forgot,the injectors are remanufactured i got from Amazon.
Drock22
Jul 2, 2012 01:05 PM
thekingtcb
Nov 11, 2011 06:52 PM
97 Civic coupe
Sep 27, 2010 09:13 PM
Emerica475
Dec 26, 2008 12:52 AM
03CivicEX03
16
Apr 17, 2005 02:05 AM
