Code 1457
Old Apr 12, 2019
Nparedes's Avatar
Nparedes is an unknown quantity at this point
Code 1457
So trying to pass smog in California. I keep getting the stupid evap code 1457, I have changed the canister vent valve and canister and I’m still getting a check engine light. Anyone have any other suggestions of where I should check next? I’ve heard gas cap going to buy one today. Thanks
Old Apr 12, 2019
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
Re: Code 1457
Did you use aftermarket parts or OEM Honda? Sometimes it makes a difference.
Old Apr 12, 2019
Re: Code 1457
FFS you didn't even tell us what year the car is.
You need to post all details about your car: Year, # of doors, trim level, trans type, engine size/type,
Or the complete vin would be just as handy
Old Apr 13, 2019
Nparedes's Avatar
Re: Code 1457
Sorry it is a 2003 4 door lx with an automatic transmission about 565000 miles on it. I used Honda parts on the valve canister is from Orileys. Would a by pass valve cause this light?
Old Apr 15, 2019
Re: Code 1457
Originally Posted by Nparedes
about 565000 miles
Are you fkn serious? Over a half million miles and an evap code is the only problem?
Based on this new information.........and no diagnosis, dynamic tests or component tests of any kind (reading codes is NOT diagnosis).......I might throw a purge solenoid at it and see if it sticks
Old Apr 15, 2019
Nparedes's Avatar
Re: Code 1457
yeah it’s put in some work I would love to get another couple years out of it can’t afford another car at this time.
So I did replace the purge valve today drove it around and the light came back on again. I read something about a 2 way vent solenoid? Do you know of a diagnosis I could run to check the evap system i would hate to just keep throwing parts at it. I also read something about the ecu going bad if the light is left on? Thanks for the help I’ve never had to deal with this before. Usually it’s something simple this one has been rough.
Old Apr 19, 2019
Re: Code 1457
I found this under 2003 along with one about the purge solenoid causing problems on 01-03 cars (you said you already replaced the purge though)
Googled for a copy: https://f01.justanswer.com/amedee/00...t_solenoid.pdf
Rodents love to gnaw plastic tubing, maybe some actual leak testing is in order rather than just replacing parts?
Old Apr 19, 2019
Nparedes's Avatar
Re: Code 1457
This is some good info I will definitely look into that. I just got my hands on a smoke machine, my friend will be coming over with it tomorrow and hopfully it helps find the leak. I spoke with Honda and they told me the gas cap was usually the problem, I tried that and it’s worked some far monitors have yet to clear but this has been the longest it has taken for them to clear I’m still hoping for the best. I’m about to take another long drive tonight fingers crossed it was just the stupid gas cap. Thanks for the help I will Update on the progress hopfully I can get to the bottom of this.
also any one know of a good link for a fsm for free?
Old Apr 19, 2019
Re: Code 1457
P1457 deals with the canister area, P1456 deals with the tank....so I would not normally expect a gas cap to fix the P1457 code
Also, the computer has to detect the problem twice before turning on the check engine light.
Search is a wonderful thing
https://www.civicforums.com/forums/1...e-updated.html
most recent links on the last page, and most of these cover cars world wide so be careful about what info you try to use....make sure it's actually for the car/engine/trans/etc that you have
Old May 1, 2019
Nparedes's Avatar
Re: Code 1457
So I finally passed smog. Did a smoke check found no leaks. Kept driving the car since a light had not come on since the gas cap change (even though it said it had a light but the monitor had not cleared yet). Put about 200 miles on the car and the light finally cleared. Long story short purge valve and cap seemed to solve my problem. Hope this might help someone else.
Old May 1, 2019
Re: Code 1457
thanks for giving feedback!
EMAN64
52
Feb 29, 2020 06:08 AM
Fez
Sep 20, 2017 12:00 PM
bulls2030
Sep 14, 2017 07:56 AM
KevinMCody
Jul 1, 2017 12:59 PM
Zrwizard
Dec 21, 2011 06:45 AM
