CKP sensor wont go all the way?
Old Mar 12, 2019
elfred's Avatar
elfred is an unknown quantity at this point
Hi HondaCivicforums!!!
So I did my timing belt replacement on my 2001 Acura EL 1.7,
I forgot that I should just unbolt it, instead I disconnect it from the harness, my bad, and ehen I sm trying to reconnect it wont go all the way, is it just me that thinking too much about connecting all the way the CKP sensor to wire harness, or is it reaaly loose, it is snug already, scared to push and force it all the way, I might damage anything, plastic or the pin connector or bend all the way.
Below pics, need advice on this thanks.
Does it really ended up hear almost halfway connected or must all the way?
Camshaft Position Sensor goes all the way dmoothly.
Only this Crankshaft wont go flyshed to the connector wire harness.
Pkease need advice on this thanks in advance!!!
Cheers!!!
ELFred
Old Mar 13, 2019
Re: CKP sensor wont go all the way?
Please start posting on the proper section.7th gen root section is not for mechanical troubles.
moving thread gain.
Old Mar 13, 2019
What's keeping it from fully seating?
Look
Old Mar 13, 2019
elfred's Avatar
Look
Hello yeah thanks got it the mint color rubber grommet on the inside obstruct it, but make a way by doing it carefully, wiggle it, and now it is okey, I hear the click now.
Cheers!
ELFred
Graphite07
Sep 30, 2018 09:02 AM
TD29064
General 7th Gen
Jul 18, 2018 07:16 AM
Rob A Gonzales
Transmission
Jan 24, 2018 03:51 PM
mullinad
Jul 29, 2002 09:57 PM
