Headlights flicker with RPM change
Old Dec 27, 2020
devolic's Avatar
devolic is an unknown quantity at this point
Cool Headlights flicker with RPM change
Hi guys title says it all. They don't completely go dark but dim as engine speed changes. The dealer said that the alternator is fine and the battery has been replaced with the same result. Seems like some kind of voltage regulator or something like that. what do you think?
Old Dec 27, 2020
BrotatoChip's Avatar
Super Moderator
Re: Headlights flicker with RPM change
Voltage regulator is part of the alternator. Do they dim enough where it's really noticeable?
Old Dec 27, 2020
ELD also has a role in voltage regulation, as well. I couldn't tell you how that thing works. I had my 2002's ELD start to go, and cause a bunch of other codes to be thrown, but one was definitely a P1298. I replaced the ELD (like a $20 part and takes 10 minutes), reset codes, and the other seemingly random codes went away.
A bit of dimming under low load/low RPM is normal.
Old Dec 27, 2020
devolic's Avatar
yes, at idle they don't dim. if I just touch the accelerator it's noticeable even in park.
Old Dec 27, 2020
devolic's Avatar
What does ELD stand for?
Old Dec 27, 2020
Super Moderator
Electronic load detector. Basically it determines how much electrical demand there is and can control the alternator based on that info.
Old Dec 28, 2020
EM2-EMMA's Avatar
I’m a guy. My car’s name is Emma.
EM2-EMMA is an unknown quantity at this point
Im having the same issue. I’ve yet to replace the ELD or the alternator. I do have a new battery. I’ll try those remedies and let you know.
Old Dec 29, 2020
devolic's Avatar
ok thnx, tell me what you find out.
Old Dec 29, 2020
If you guys want some reading material about the ELD
Meet your ELD - Electrical Load Detector....
Part number and removal in this post of mine
Old Dec 29, 2020
EM2-EMMA's Avatar
Awesome. Thanks
Old Feb 10, 2021
EM2-EMMA's Avatar
So I haven’t changed out the ELD or alt yet but my issue has gone away. Lol
you know that law of thermodynamics that says stuff will fix it self? 😜
Old Mar 22, 2022
EM2-EMMA's Avatar
Late response. Issue came back. Replaced eld. Been working fine since then
IronFist
Sep 25, 2015 07:13 PM
Bricoleur
Sep 9, 2015 12:23 PM
RobertK
17
Nov 9, 2012 11:20 PM
teenwolf
Oct 25, 2008 12:03 PM
tdiddy
Dec 16, 2003 02:32 AM
