What, Besides the Alternator, Can Cause Pulsing Headlights?
Old Feb 17, 2019
RyanHostetler's Avatar
RyanHostetler is an unknown quantity at this point
When I first start my 05 Civic EX, especially in the cold, the headlights and the dome light pulse significantly, seemingly on rhythm. I have read that this can be caused by a bad alternator. Is there anything else that can potentially cause this before I look at replacing the alternator?
Old Feb 17, 2019
Re: What, Besides the Alternator, Can Cause Pulsing Headlights?
Stock sound system? Any big electronic upgrades done? Could possibly be an overactive/faulty ELD (I know when the ELD in my 2002 went bad, other codes started popping up and went away when I replaced it)
Old Feb 17, 2019
It does have a stock stereo and I have not done any sort of electronics upgrades.
Old Feb 17, 2019
I do have some issues with the power outlet. Sometimes it works and sometimes it does not. I have to wiggle whatever is plugged into it for it to work. Do you think that could be a factor here?
Old Feb 17, 2019
since this is not a "how to DIY" article, moving out of the DIY section to the correct section of the forums.
Old Feb 17, 2019
GolNat's Avatar
Prelude Owner
Check all your ground wires. Make sure you have a good solid clean connection.
You could be getting interference from something also like a charging or audio cable.
03-GoGo-coupe
Oct 28, 2012 08:46 PM
waldenp
Jan 9, 2012 01:32 PM
gameboi499
Sep 29, 2007 09:08 PM
Sivion
Jul 4, 2003 02:57 PM
pinkytoe
Jun 12, 2002 10:32 AM
