Regular Maintenance Post questions about regular maintenance here
Correct tire pressure
Old Jun 13, 2019
honda13820's Avatar
honda13820 is an unknown quantity at this point
I bought my first Honda today. Its a 2019 Honda Civic EX. I checked the tire pressure before test driving it and found all four tires are set to 38 PSI. However, when I open the driver door to see what is the ideal tire pressure it says it should be set to 32 PSI. So my question for the forum is: What is the ideal tire pressure for this year, make, and model? Should I follow the tag inside the door and put all four to 32 PSI or should I leave it at 38 PSI or somewhere in between?
Old Jun 13, 2019
Re: Correct tire pressure
door jamb tag.
they bump pressures for shipping to avoid flat spot tires, should have been adjusted before giving to you
important note that very few understands: Honda does not own the dealers, if the dealer does not do what Honda recommends, it's the dealers' fault. If you want to complain, complain with the dealer.
Old Jun 19, 2019
i set mine at 35 and call it a day. Dealer penciled in the PDI part of tire pressures for mine, and when I got it home, all 4 tires were reading 55psi.
Old Jun 19, 2019
mikey1's Avatar
tires are always over inflated at the factory,
my tires were over 40 PSI when i picked up my 2018 civic,
i go by the sticker in the drivers door which is 32 PSI cold,
i check my tires in the morning after the vehicle has been sitting overnight
Old Jun 19, 2019
mac25's Avatar
Dr Krieger of Modification
Omg, lol. This is like one of my top annoying conversations with customers.
Me: "And if you could just open the door so I can check the tire pressure spec."
Random: "Isn't the spec listed on the tire."
Me: "No, that's the maximum safe listing before the tire wont grip the round safely; and these tires can be used on vehicles with different weights."
Random: "Oh... I went higher just in case."
Me: checks pressure, sees 80psi! Lol
shahzad
Feb 27, 2012 06:36 PM
zackde
Oct 12, 2004 06:44 PM
PJG
Feb 16, 2004 08:53 AM
BIG
Oct 19, 2003 11:32 PM
civicex2002
Nov 4, 2002 04:32 PM
