Air Conditioning Post your questions about air conditioning here!
2018 civic ac compressor
Old May 12, 2019
Mpeter's Avatar
Mpeter is an unknown quantity at this point
I just bought a 2018 civic ex-l with the 1.5 turbo. Went to use the air conditioning and the compressor is not kicking on. I checked the 10amp fuse, and that was good, is there a relay somewhere I can check? Also, the vehicle only has 3900 miles. So the compressor clutch shouldn't be worn out. Let me know any thoughts or ideas you have, thanks in advance
Old May 12, 2019
Re: 2018 civic ac compressor
it should have a warranty.
Use it
Old May 12, 2019
Mpeter's Avatar
No warranty. Has a rebuilt title. It is the only thing I've found wrong with it. And its gotta be a relay, a wire, or the clutch. Which the clutch should be fine. Unless I'm missing something else to check
Old May 13, 2019
Mpeter's Avatar
I did find the relay for the compressor, just not sure how exactly to check it. I pulled it, and shook it, heard no rattles...
Old May 13, 2019
Is the system low or empty?
Old May 13, 2019
Mpeter's Avatar
I am not sure, how does one check? I know the fuse and relay "seem" good, and the compressor clutch doesn't appear to be engaging. Therefore, no cold air.
Old May 13, 2019
Same way anyone would check on any other automotive AC system, except you now need the specialized equipment to service current AC systems that use HFO-1234yf refrigerant
Personally, I'd begin with my scanner and check for fault codes and read the ACPSI value in the live data list, then decide what my next step would be
Old May 13, 2019
Mpeter's Avatar
Sounds easy enough, if only I had a scanner and the special equipment for ac service, haha. Thanks though, maybe I'll do some checking locally see if someone has some stuff to help me out
Old Jul 16, 2019
fijiblue05's Avatar
fijiblue05 is an unknown quantity at this point
The A/C compressor in my 2016 Civic EX had a leaking seal and had leaked onto the clutch and coil. It was going to cost nearly $1600 at the Honda dealership. (I have about 86k miles and it's less than 4 years old.) Luckily I had an extended warranty from CNA National Warranty Corporation. It only cost a $100 deductible to replace the A/C compressor, clutch, and coil at the Honda dealership.
Old Jul 16, 2019
Mpeter's Avatar
I have a rebuilt title, so no warranty, and I don't want to buy a 3rd party warranty, especially with only 6k miles. I did add refrigerant and as of right now, the AC is working. We'll see how long it lasts, if I have a bad seal.
Old Jul 17, 2019
fijiblue05's Avatar
I did some research before when my A/C stopped feeling cold to see if there were any common issues. I didn't see much posted here from our forum users regarding issues. But elsewhere it seemed like most people who had issues with the A/C determined the issue was the compressor. That's awesome that all yours needs is the refrigerant for now!
Old Nov 12, 2019
fijiblue05's Avatar
Hey guys! I just received a letter from Honda
Warranty Extension: A/C Condenser Leaks
This warranty only covers vehicles that have a defective air conditioning condenser installed at the factory. The A/C condenser was not manufactured to specification. As a result, tiny holes may develop in the condenser tube walls that allow refrigerant to leak out. The warranty will not apply to any vehicle that has a leaking condenser due to foreign object damage.
American Honda is extending the warranty on the A/C condenser to 10 years from the original date of purchase with no mileage limit.
This warranty extension will not apply to any vehicle that has even been declared a total loss or sold for salvage by a financial institution or insurer, or has a branded or similar title under any state's law.
What should you do?
If the vehicle's A/C does not blow cold air, go to any authorized Honda dealer to have the vehicle inspected. If the A/C condenser is leaking because it was not manufactured to specification, it will be replaced. This work will be done for free. Please plan to leave your vehicle at the dealer for at least a day to allow them flexibility in scheduling.
Old Nov 13, 2019
Mpeter's Avatar
My ac was still working up until it got cold here, then I obviously stopped using it. So the letter is nice of them. I like how it specifies that any and all salvage or similar titles vehicles are excluded. (Because the rear damage my car received, totally messed up the compressor. Which was already trash from the factory) haha. Oh well. At least so far I'm having good luck, just not with warranty claims.
Old Sep 7, 2020
rajuncajun9's Avatar
rajuncajun9 is an unknown quantity at this point
I have the same car, 2018 Honda Civic Turbo, and have the A/C problems. The dealership says it is the 'compressor'. $1200+ repair. Who else is having this problem?
I haven't really been using the A/C much until recent, but it can be cold and then not, cold, then not. I think the right side is cold and the driver side is not too. Not sure what is going on.
May be past my warranty period with all the Covid etc.
Old Sep 7, 2020
I've seen it. The 2016 Civic I bought for my GFs mother needs a compressor.
A symptom of low refrigerant charge.
That means the system has a leak.
They apparently found the source of your leak, the compressor.
Leak needs fixed.
Replace compressor.
The price is the price.
This new refrigerant is not cheap, and neither are parts and labor.
Don't wait until its definitely expired. Call your dealer and find out when yours does.
3 years or 36000 miles, unless you bought a extended warranty/service contract that covers it
Ohmster
Air Conditioning
May 23, 2021 08:10 AM
Kyle Gleason
Jul 20, 2017 12:07 AM
Roman Rembacz
Jul 16, 2015 12:30 PM
davidezerron
May 30, 2015 02:45 PM
Rufus
Apr 26, 2009 11:32 AM
