8th Gen 2006 - 2011.
AC starts without turning on
Old Jul 15, 2015
Roman Rembacz's Avatar
Roman Rembacz is an unknown quantity at this point
Hi,
Had my engine replaced under TSB 10-048 and at same time replaced compressor as previous one blew up. Now with compressor clutch connected and relay installed, compressor wont's turn off. If I disconnect comp clutch relay, compressor wont start but both fans turn on immediately after inserting key. If wires to clutch are disconnected but relay left in, only rad fan works and cpompressor does not. AC panel in car does nothing
Old Jul 15, 2015
Re: AC starts without turning on
First swap the clutch relay with an identical relay, maybe it's just stuck on.
If you determine it is not a stuck clutch relay, then I might go to the HVAC panel and remove and unplug it, see if that lets the compressor shut off.
Define 'nothing'?
Old Jul 16, 2015
The AC ON button has no effect to turn off the compressor from running. Is it possible the dealer damaged the ECM or HVAC Ctl unit when they swapped out the new engine block ?
Old Jul 16, 2015
CraigW's Avatar
Did it literally blow ??
If so it may have been constantly on previously.
Old Jul 16, 2015
CraigW's Avatar
And this,
Old Jul 16, 2015
If this is a brand new problem that was not present when you dropped the car off with them, maybe you should be banging on your dealerships door asking these questions.
Short answer is probably no, they should have had nothing to do with the problem.....but none of us were there to see what happened.
I know if I do the same engine job there would be no relationship other than unplugging the PCM and harnesses, which has been done with zero issues on countless other cars.
SOMEONE needs to figure out the real cause of the problem FIRST...then figure out what needs done to correct it.
BEFORE pointing the finger of blame.
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
ayoitzjulesdx98
May 13, 2015 08:31 PM
SSMatey
Apr 13, 2015 06:09 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
black2k1vtec
Dec 6, 2001 09:49 PM
