Unable to fill fuel tank
Old Jun 16, 2021
dborden702's Avatar
dborden702 is an unknown quantity at this point
Question Unable to fill fuel tank
I just bought a used 2020 Honda Civic EX-L Sedan with 4500 miles. I just went through my first tank of gas. The car does not have a gas cap, but instead an automatic cap built into the gas door with little spring loaded door on fuel filler tube. When I tried to fill the tank, The auto shut off on the pump keeps shutting off like it's full and I can't squeeze the pump handle anymore. It only took 7.1 gallons (had 1/4 tank to start with). When I started the car again, the tank was between 3/4 and full on the gauge. Is there a trick to get the tank all the way full?
Thanks
Old Jun 16, 2021
Re: Unable to fill fuel tank
Mine fills 10-11 gallons just fine on empty.. Then again, the little lock thingy on the pumps, I don't squeeze all the way, I lock it in on the first click no matter where I go
edit: my cousin had that issue filling up before, going full squeeze on pumps and it'd shut off. She called me in a panic not knowing what to do. Told her to squeeze the lever gently and it worked just fine.
Old Jun 16, 2021
dborden702's Avatar
Thanks - I'll try that next time I fill up
Old Jun 16, 2021
BrotatoChip's Avatar
Super Moderator
I have to do this on my '02 Civic sometimes as well. Some pumps are just too fast.
Old Jun 17, 2021
123Krash's Avatar
123Krash is an unknown quantity at this point
Pump slowly...
Old Jun 19, 2021
still better than miatas... 1-3rd generations you need to point the fuel filler in the direction of the car, otherwise the pump will stop early.
Old Jun 21, 2022
Mike Towns's Avatar
Mike Towns is an unknown quantity at this point
possible a bad evap vent valve.
93honda
Sep 29, 2012 08:56 AM
jd702
Aug 18, 2010 07:25 AM
asb
Buy, Sell, & Trade - Archive
21
Dec 1, 2007 07:40 AM
shroomster
18
Aug 19, 2005 04:25 PM
bmy
Feb 6, 2002 12:17 AM
