Fuel smell after filling tank...
Old Aug 18, 2010
jd702's Avatar
jd702 is an unknown quantity at this point
I'm the original owner of an 02 civic lx manual and haven't had any issues w/ the car til now....the past 4 times I've filled up, there's been a lingering, heinous fuel smell coming from the car and making the interior AND entire garage stink of fuel. The smell is at it's peak during the first 3 days after the tank has been filled. It seems the more I drive it and the tank gets lower, the odor dicipates and doesn't surface again til the next fill up. I'm not topping off because all the gas pumps out here have auto shut off, and I always make sure that the gas cap is on tight, so I doubt it's that.
I don't know what the problem is...this is the 1st summer in Las Vegas that this has happened. I'm not a pro, but I think maybe a fuel line or tank has been damaged or cracked, maybe the cap to the fuel pump is loose...who knows.
Any advice/suggestions???
Old Aug 18, 2010
Mad Dog Tannen's Avatar
Re: Fuel smell after filling tank...
First thing I would do is look for broken/craked fuel lines. Rubber parts deteriorate faster than metal. Look around the fuel pump especially. I would not worry about the tank unless it has been damaged or is rusty. May be from the EVAP system.
Old Aug 18, 2010
jd702's Avatar
Thanks for the info, much appreciated
Old Aug 18, 2010
Prodresurgence's Avatar
Prodresurgence will become famous soon enough
Pretty sure that car has a plastic gas tank and filler neck.
Green02civic
Jul 27, 2015 10:48 PM
DerbyDad03
Jul 27, 2015 11:34 AM
LorenzoC0395
Jul 14, 2015 08:46 PM
Jul 12, 2015 11:54 AM
1khilari
Jul 9, 2015 08:12 PM
